Home > Message Board > Car Audio > Amplifiers > Archive through April 17, 2006 > I need help choosing these subs and a...
Author Thread: I need help choosing these subs and amp..?
Username: Rollout4877
i want to get 2 KICKER L7 SOLOBARIC 12's but i dont know whether to get 2 or 4 ohms. both or dual voice coil. also i want the POWER ACOUSTIK TS1920-2 model amp. its 1920 watts. what do you guys suggest i do? the subs are 1500 watts peak. would this be a real nice system?
Username: Night_mirage
Amman
Jordan
Post Number: 236
does this amp stable @ 2 ohm
if its 2ohm go with dual 4ohm sub's
im not sure.... heres the specs..
Features:
Synchronized Lightning Pulse Dish
PWM MOSFET Power Supply
Diamond Cut Heatsink
High or Low Level Inputs
Variable 40-250 Hz Low-Pass Crossover
Variable 40-250 Hz High-Pass Crossover
Variable 60-200 Hz Subsonic Filter
Variable 18 dB Bass Boost at 40 Hz
Tri-Mode Capable
2-Ohm Stereo / 4-Ohm Mono Stable
3-Way Protection Circuit
Platinum-Plated RCA Terminals
4 Gauge Power and Ground Connections
RCA Line Level Outputs
Remote Subwoofer Level Control Included
2-Channel Amp Specifications
Amplifier Type: 2-channel
RMS Power @ 4 Ohms: 370W x 2
THD at 4-Ohm RMS Power: 0.02 %
Bridged RMS Power @ 4 Ohms: 880W x 1
Speaker Level Inputs: yes
Preamp Outputs: yes
Built-In Crossovers: HP/LP
Bass Boost: 0 - 18 dB
Frequency Response: 10-30,000 Hz
Signal to Noise Ratio: 98 dB
Dimensions: 20.5 L x 11 W x 2.25 H
and do you think thats enough power for the subs i want? their RMS is 750, 1500 peak
Username: Theelfkeeper
Stockbridge, GA
Post Number: 1754
that'll push them, but not to their full potential.
you'll have to get the dual 4 ohm versions. wire the coils together in series, then the subs together in parallel for a 4 ohm final load. bridge the amp for the 880 watts.
that'll power one nicely, but it'll underpower two.
Username: Dustin3
Tigard, Or
U.S.
Post Number: 798
the amp specs are:
370 watts RMS x 2 at 4 ohms (440 watts RMS x 2 at 2 ohms)
880 watts RMS x 1 in bridged mode (4-ohm stable in bridged mode)
for future reference, never look at the peak numbers like you did when you said it 1920 watts. thats the peak. you always want to look at the RMS numbers.
the solobaric L7 has an rms rating of 750 per woofer meaning you need an amp that puts out around 1500 watts @ 2 or 4 ohms depending on the subs you get.
if you hooked those sub to that amp it you would be underpower the subs major and most likely that PA amp would go into protection from being too hot.
if i were you wanting to get those subs this is what i would get:
AMP =
http://cgi.ebay.com/HIFONICS-BXi1606D-BRUTUS-CLASS-D-MONO-AMP-BXi-1606d-NEW_W0QQ itemZ9711169830QQcategoryZ18797QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Subs =
(2) 12 inch L7's - dual voice coil 4 ohm subs
and then wire it to 1 ohm and the subs will be getting around the recommended watts.
what about a boss audio pd3000? the specs are..
Max power 3000 Watts
RMS power, 4 ohms 350w x 2
RMS power 2 ohms 700w x 2
RMS power 1 ohm 1000w x 1
RMS power 1/2 ohm 1500w x 1
Frequency response (+/- 3dB) 9Hz to50kHz
Signal-to-noise ratio>105dB
Channel separation>90dB
Low pass Crossover 50Hz-100Hz
High pass Crossover 120Hz-720Hz
Bass boost 0-+18dB
Bass boost Frequency 50Hz-100Hz
Dimensions, LxWxH
20 1/8" x 13 3/8" x 2 3/4"
MORE FEATURES
High current operation
VU meters (power level)
Cooling fans
Line output For system building
Gain control
Power and Protection LEDs
MOSFET Power supply
Username: Dustin3
Tigard, Or
U.S.
Post Number: 803
i would just get what i said above. you will be alot more happy
Home > Message Board > Car Audio > Amplifiers > Archive through April 17, 2006 > I need help choosing these subs and a... [ « Previous ] [ Next » ]
