Thread: Too much power |
Bronze Member Username: Sleepyvw
Omaha,
NE
Post Number: 41 Registered: Jan-06
| Posted on Friday, April 14, 2006 - 10:46 pm: |
i purchased an alpine type r thinking it was rated at 500wrms but i guess it was an older version rated at 300wrms. I bought an alpine m650 amp (600wrms) for it. will this be too much power for this sub? also, what are some possible consequences that may occur? thanks |
Gold Member Username: B101
Queen City,
NC
Post Number: 2300 Registered: Sep-05
| Posted on Friday, April 14, 2006 - 11:36 pm: |
it will be just fine... just set gains properly, and have a good chargin system... |
Omaha,
NE
Post Number: 42 Registered: Jan-06
| Posted on Saturday, April 15, 2006 - 12:46 am: |
so doubling the amount of rms power to the sub will be absolutely ok as long as i set the gains properly
Silver Member Username: Fiber
Post Number: 137 Registered: Mar-06
| Posted on Saturday, April 15, 2006 - 02:11 am: |
yes just dont turn the gain past halfway |
Silver Member Username: N2audio
Lawrence,
Ks
Post Number: 803 Registered: Mar-04
| Posted on Saturday, April 15, 2006 - 02:16 am: |
"yes just dont turn the gain past halfway" That depends entirely on the HU - 1/2 could be WAY too much. The point is - the amp's gain and the HU's volume control power to the sub. If you want to damage it I'm sure you can. If you want it to last a long time that can be done about as easily. |
Gold Member Username: Rovin
Trinidad & T...
Post Number: 7314 Registered: Jul-05
| Posted on Saturday, April 15, 2006 - 11:40 am: |
i fully agree with him ^^^^^^^ it all depends on the way the gains controls are layed out in each brand etc .... |
Gold Member Username: Rzarector
Coquitlam,
Bc
Post Number: 1050 Registered: Dec-04
| Posted on Saturday, April 15, 2006 - 07:02 pm: |
you will want to set the gains correctly to your head unit and then down some more, that sub doesnt handle 500+ watts very good ive tried :p and it died after bout a week |
Omaha,
NE
Post Number: 43 Registered: Jan-06
| Posted on Saturday, April 15, 2006 - 07:36 pm: |
with this amp should i just go ahead and purchase the newer 05 models? |
