Thread: I really need help |
Bronze Member Username: Drizzo
Post Number: 14 Registered: Apr-06
| Posted on Friday, April 14, 2006 - 08:18 pm: |
dont kno where to connect tha remote wire in bak of a stock cd player. |
Silver Member Username: Bnd_rulez
Phoenix,
AZ
Post Number: 888 Registered: Mar-05
| Posted on Friday, April 14, 2006 - 08:42 pm: |
Use your fuse box. Hook it up to like the power antenna or something that comes on when the car turns on. |
Silver Member Username: Dustin3
Tigard,
Or
U.S.
Post Number: 783 Registered: Oct-05
| Posted on Friday, April 14, 2006 - 09:25 pm: |
use: www.bcae1.com and www.the12volt.com |
Gold Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 1741 Registered: Feb-05
| Posted on Friday, April 14, 2006 - 09:30 pm: |
just hook it to the fuse box, constant lead, and put a switch in the line to turn it on and off. do read the links above though. very helpful information. |
