Thread: Battery issues....... |
Bronze Member Username: Hockeyknight
Post Number: 23 Registered: Apr-06
| Posted on Friday, April 14, 2006 - 07:06 pm: |
ok i dont know much bout amps and stuff and i was wondering how it will effect my car battery??? i was also wondering if i should get a cap and what exactly that will do? thanks fer the help! |
Silver Member Username: Bnd_rulez
Phoenix,
AZ
Post Number: 889 Registered: Mar-05
| Posted on Friday, April 14, 2006 - 08:45 pm: |
Screw the cap. Get an Optima, and if you need more power, get a H.O. alternator. |
Silver Member Username: Dustin3
Tigard,
Or
U.S.
Post Number: 782 Registered: Oct-05
| Posted on Friday, April 14, 2006 - 09:23 pm: |
the car will pull the power away from the battery and drain it unless you have a proper HO alternator. The capacitor would just put more strain on your alternator so dont get a cap. if you wanted to know, the cap just levels out the power kindof, and people would say that "it will make your subs hit harder" |
Gold Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 1742 Registered: Feb-05
| Posted on Friday, April 14, 2006 - 09:32 pm: |
it can make the amps a little more responsive, but won't make them "hit harder." a cap does nothing without a proper sized alternator. |
Tigard,
Or
U.S.
Post Number: 786 Registered: Oct-05
| Posted on Friday, April 14, 2006 - 09:37 pm: |
i know that it doesnt make it 'hit harder" i just said that i have heard people say that which is ridic. it makes the amp more efficient is a better way to put it |
