Home > Message Board > Car Audio > Head Units > Archive through May 04, 2006 > Wanted!! rear infinity speaker for je...
Author Thread: Wanted!! rear infinity speaker for jeep grand cherokee 97-98
Username: Camdawg
I need the rear infinity speaker for my 97 grand cherokee, if anyone has one or knows where I can get one,at a fair price let me know. Thanks
Username: Makmillion
United States
Post Number: 57
Stock or aftermarket?
Username: Camdawg
It really doesn't matter as long as it has the tweeter in it with the same connection and screw pattern, it might have to be stock. I really dont want to rewire anything.
Username: Illuminator
Post Number: 2864
Best place would be a junkyard.
Otherwise, check Ebay or the Jeep dealership...
Username: Camdawg
I checked ebay, they only had front one's and the dealer wants $118 for one. Well thanks for your help, Ill keep on looking thanks. See ya
Post Number: 2867
Honestly, if they're going to charge you that much, you'd be better off just getting new speakers, possibly even Infinity's made by Infinity. Stock systems with the Harman/Kardon brandnames (JBL, Infinity) usually aren't that great to begin with-there's hardly any difference between the 'regular' stock system and the one with the Inifinty name on it.
Username: Camdawg
Yeah I have thought of replacing them with nre one's but I wanted to same one's just so I could have the same bolt pattern and it would just snap right in, but your right if its that much I could take it to (hell best buy) and get it done cheaper. Thanks
Home > Message Board > Car Audio > Head Units > Archive through May 04, 2006 > Wanted!! rear infinity speaker for je... [ « Previous ] [ Next » ]
