Thread: Profile AP2000 amp? any good |
New member Username: Bumpthat
Post Number: 6 Registered: Mar-06
| Posted on Friday, April 14, 2006 - 01:54 am: |
http://www.crutchfield.com/S-XhKTgmV9JA1/cgi-bin/ProdView.asp?g=120&I=489AP2000 never heard of Profile. are they any good? its a 2way amp. 480w x2 at 2 ohms i am looking to wire it to 2 Alpine 10" Type-R's http://www.crutchfield.com/S-XhKTgmV9JA1/cgi-bin/ProdView.asp?wm=fp&I=500SWR1242 the subs are dual 4ohm voice coils. i (think) i was told that i can run those at 2ohm's if i have a 2way amp. (i asked this question in the subwoofer forum) all this stuff is confusing to me. i just dont want to take any chances. thanks |
Gold Member Username: James1115
Ct
Post Number: 5609 Registered: Dec-04
| Posted on Friday, April 14, 2006 - 02:00 am: |
nope its garbage. the subs are alright but the amp isnt. look into a mb quart raa 1000 for those. |
Silver Member Username: James_g
TN
Post Number: 446 Registered: Jul-05
| Posted on Friday, April 14, 2006 - 02:07 am: |
Profile was junk back in the day. Haven't had any experience with them in years, but I've read they're still the same low-quality products. I owned a Cali. Series A600 and it was a complete joke. They claimed 300X2 at 2 ohms. I'd say it was lucky to push 200w, period. It did have that "cool" light strip, though. LMAO. |
Ct
Post Number: 5612 Registered: Dec-04
| Posted on Friday, April 14, 2006 - 02:16 am: |
lol I remember that amp lol! We used to call it the California Penile from the move major League lol! |
Silver Member Username: N2audio
Lawrence,
Ks
Post Number: 797 Registered: Mar-04
| Posted on Friday, April 14, 2006 - 09:53 am: |
on most forums Profile is often recommended as one of the best budget amps you can get. No, they're no kicer, or orion, or RF, but for the cost you can't do a lot better. Run a search at Sounddomain or caraudio.com - there are MANY reviews, some with pix, and very few users have been disappointed. |
Post Number: 7 Registered: Mar-06
| Posted on Friday, April 14, 2006 - 03:03 pm: |
^^^ thats the reason I asked because on Crutchfield it got good reviews. But I am hestiant to trust something so cheap. |
New member Username: 30hrtz
Raleigh,
Nc
U.s.a
| Posted on Friday, April 14, 2006 - 11:45 pm: |
i got a mono block profile amp.ap600 its 300w at 4 ohms and 420w at 2 ohms.i got it running in 2 ohm to a kicker 10 inch L5 dual 4 ohm voic coils.It slams hard and has been for 1 and a half years.flawless performance from a cheap amp.if youre on a budget,get it.ive read some bad stuff about the online dealers amps like hifonics and lanzar.like d.o.a.crutchfield gives 3 yr warrenty on profile. |
TN
Post Number: 448 Registered: Jul-05
| Posted on Saturday, April 15, 2006 - 01:55 am: |
I hope their quality has improved dramatically over the years. If not, then those people at the other forums are liars or they are just plain fools. My A600 was complete junk.....right there with the Pyramid trash. |
Silver Member Username: Gage
Post Number: 183 Registered: Feb-06
| Posted on Saturday, April 15, 2006 - 02:01 am: |
shane why not just get an audiobahn a800t or whatever their 800 watt rms amp is its only lik 150 shipped and its a nice amp for the money probably better than this stuff |
Lawrence,
Ks
Post Number: 804 Registered: Mar-04
| Posted on Saturday, April 15, 2006 - 02:30 am: |
http://www.caraudio.com/forum/showthread.php?t=138358&highlight=profile http://www.caraudio.com/forum/showthread.php?t=136788&highlight=profile http://www.caraudio.com/forum/showthread.php?t=121390&highlight=profile http://forum.sounddomain.com/ubb/ultimatebb.php?ubb=get_topic;f=2;t=043777#000000 |
Post Number: 8 Registered: Mar-06
| Posted on Saturday, April 15, 2006 - 03:50 am: |
thanks for the reviews and also the recommendation the audiobahn...i'm checkin that out right now |
