Home > Message Board > Car Audio > Amplifiers > Archive through April 17, 2006 > Check This Out
Author Thread: Check This Out
Username: Do_em_dirty816
Kansas City, MO
Post Number: 68
I need help/advice on choosing an amp to power 3 infinity 1230w's. They're each 300 watt rms so 900 total; which means i'll need at least a 1000 watt mono amp but anything from 1000- 1500 will be good so i can have some headroom with the gains set low. My budget is running kind of low so i'll be spending up to $280 maybe $300. Thanks in advance
PS: Some of the amps I have in mind are the hifonics brutus bx1205, mb quart raa1000, and the MA AUDIO HK2000D... If you need links just ask.
Kansas City, MO
Post Number: 70
i didnt mean to start 2 threads admin can delete
Username: Matt12490
Benicia, California
Post Number: 672
i would go with that mb quart out of those choices
Kansas City, MO
Post Number: 71
Do you think the mbquart will put out more CLEANER watts and run better for the buck? Also are there any other choices of 1000 - 1200 watt amps in $200 - $275 range.
Username: Matt12490
Benicia, California
Post Number: 678
i dont think an amp can put out CLEANER watts then other amps, just actual wattage. that mb quart would put out the actual wattage it says, maybe a lil more. for that range i cant think of anything better right now..
Kansas City, MO
Post Number: 72
alright thanks for your input... what GOOD amps can you think of without a budget because right now I dont know what my budget is going to be.
Username: Matt12490
Benicia, California
Post Number: 679
kicker kx1200.1 or sx1250.1
Ed Nine.1
Orion 1200d
JL 1000/1
PPI DCX 1500.1
JBL gto1200.1
Helix Dark Blue 1000.1
Memphis 16-PRD1000.1 or Memphis 16-MCD1000
Mmats D1500.1
check those out..
Kansas City, MO
Post Number: 73
i'll look into those. thanks alot for your input
Home > Message Board > Car Audio > Amplifiers > Archive through April 17, 2006 > Check This Out [ « Previous ] [ Next » ]
