Home > Message Board > Car Audio > Amplifiers > Archive through April 17, 2006 > Check This Out
Author Thread: Check This Out
Username: Do_em_dirty816
Kansas City, MO
Post Number: 67
I need help/advice on choosing an amp to power 3 infinity 1230w's. They're each 300 watt rms so 900 total; which means i'll need at least a 1000 watt mono amp but anything from 1000- 1500 will be good so i can have some headroom with the gains set low. My budget is running kind of low so i'll be spending up to $280 maybe $300. Thanks in advance
PS: Some of the amps I have in mind are the hifonics brutus bx1205, mb quart raa1000, and the MA AUDIO HK2000D... If you need links just ask.
Username: Joebruce
KY
U.S.A.
Post Number: 333
Id go with the mb quart,i have one powering my 12w6v2 and it sounds great. It will problly put out more than 1000 watts. I dont know why they stopped makin em they are great amps. But are u sure that those three subs can be wired to get a 1 ohm load?
Kansas City, MO
Post Number: 69
it should be 1.3 ohm load
Home > Message Board > Car Audio > Amplifiers > Archive through April 17, 2006 > Check This Out [ « Previous ] [ Next » ]
