Thread: HELP!!!!!!!!! Kenwood krc 358r |
New member Username: Cbandy
Post Number: 1 Registered: Apr-06
| Posted on Thursday, April 13, 2006 - 08:42 am: |
Hi, Just bought the krc 358r header unit second hand but when i plug my Kenwood (which is from a previous head unit but stil kenwood)disc changer in and press the blue button to select cassette or cd it just says on the dispalay All Off. Is it a problem i can fix? I also do not have the manual so maybe it is something i am not doing correctly. It will not select the cassette either. Regards Andy |
Gold Member Username: Illuminator
Post Number: 2855 Registered: Apr-05
| Posted on Thursday, April 13, 2006 - 10:21 am: |
I believe it will only select the cassette if you have a cassette inserted. As for the CD changer, you might need to go to the menu and turn it on from there. |
Post Number: 2 Registered: Apr-06
| Posted on Thursday, April 13, 2006 - 10:37 am: |
Cheers mate. Cassette inserted but still no joy. CD unit is powered up because i can eject the cartridge. Will have another mess about with the menu but it is driving me mad. On the last HU(Which was stolen)I just had to select with the blue button. |
Post Number: 2857 Registered: Apr-05
| Posted on Thursday, April 13, 2006 - 10:54 am: |
What is the model number of the CD Changer? |
Post Number: 3 Registered: Apr-06
| Posted on Thursday, April 13, 2006 - 11:03 am: |
KDC C462 |
Post Number: 4 Registered: Apr-06
| Posted on Thursday, April 13, 2006 - 11:37 am: |
I just read on the Kenwood site that this changer unit is not compatible with header units manufactured before 1994 but i cannot find the date of manufacture for this header unit. That might be my problem. Any ideas????? |
Post Number: 2858 Registered: Apr-05
| Posted on Thursday, April 13, 2006 - 12:08 pm: |
I'm sure the 358R was manufactured after 1994. However, after doing some research, it looks like nearly anyone with a CD changer hooked up to the 358R is using the Kenwood KDC-C660 CD changer. Because of that, I'm thinking there still might be a compatibility issue here. Do you still have the link to the page on the Kenwood site about your CD Changer? |
Post Number: 5 Registered: Apr-06
| Posted on Friday, April 14, 2006 - 04:07 am: |
Got it working. There is a switch on the changer unit to select different types of header units. Just switched it to O and it worked. Cheers for all the info anyway. |
