Thread: Amps for type x |
Bronze Member Username: Hockeyknight
Post Number: 15 Registered: Apr-06
| Posted on Thursday, April 13, 2006 - 02:58 am: |
i got a 12" alpine type x that needs some power 1000w rms/ 3000w max would any of these amps do it any justice??????? http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3015&C FID=488802&CFTOKEN=864399aff84fcc20-9202B317-1422-7C6E-5011364BF644DC91 http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3908 http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3016 |
Silver Member Username: Djbeanpole
Naptown,
Indiana
Post Number: 150 Registered: Nov-05
| Posted on Thursday, April 13, 2006 - 01:50 pm: |
Cross posting is totally SWEET! |
Bronze Member Username: Genocyde21
Post Number: 18 Registered: Apr-06
| Posted on Thursday, April 13, 2006 - 02:09 pm: |
how many ohms? |
| Posted on Thursday, April 13, 2006 - 10:11 pm: |
4homs |
Silver Member Username: Ctmike
Ct.
Post Number: 226 Registered: Feb-06
| Posted on Thursday, April 13, 2006 - 10:19 pm: |
what's your budget? |
Post Number: 20 Registered: Apr-06
| Posted on Friday, April 14, 2006 - 06:20 pm: |
under 400 |
Silver Member Username: Johnny619
San Diego,
CA
Post Number: 109 Registered: Dec-05
| Posted on Friday, April 14, 2006 - 11:59 pm: |
How about a Alpine MRD M1005 for the type X. |
Ct.
Post Number: 235 Registered: Feb-06
| Posted on Saturday, April 15, 2006 - 12:24 am: |
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16368 little more but worth it http://carstereoexpo.com/kxki1chcaram1.html or try a nine.1 or re 12.1 |
Bronze Member Username: Nveselinovic16v
Post Number: 48 Registered: Mar-05
| Posted on Saturday, April 15, 2006 - 02:47 pm: |
hifonics is max power at 1ohm and type x is dual 4. What you need is amp that does 1.5k rms @ 12.5V. I connected the other day mtx 1501d and it plays niceley. Yo dont need nicely. before that it played with DD Z1 and it was impossible ti stay in the car... |
Gold Member Username: Bestmankind
Los Angeles,
CA
Post Number: 3620 Registered: Oct-05
| Posted on Saturday, April 15, 2006 - 05:24 pm: |
if i were you adam i would get the orion 2500d for that sub. the orion 2500d is 1700wrms@2homs. trust me that sub takes more than 1000wrms to make it move the way you want. also later on if you decide to get another one you are covered with that amp. |
Post Number: 50 Registered: Mar-05
| Posted on Sunday, April 16, 2006 - 08:55 pm: |
we just rewired the system. single X single MTX Kicks like mad, but for a bit SQ go with 1.5kw at 12V, just to keep your amp at half gain |
