Thread: Amps for type x |
Bronze Member Username: Hockeyknight
Post Number: 14 Registered: Apr-06
| Posted on Thursday, April 13, 2006 - 02:58 am: |
i got a 12" alpine type x that needs some power 1000w rms/ 3000w max would any of these amps do it any justice??????? http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3015&C FID=488802&CFTOKEN=864399aff84fcc20-9202B317-1422-7C6E-5011364BF644DC91 http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3908 http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3016 |
Bronze Member Username: _jay_
Post Number: 65 Registered: Mar-06
| Posted on Thursday, April 13, 2006 - 11:03 am: |
stay away from boss, they arn't that great idk how good the spl is but if i would have to go with any of the amps i would probly go with the SPL Z1X-3000D, or look into getting a hifonics amplifier and run it in a 1ohm load, and btw the max number means nothing always look at rms, and most companys out there overrate their products only products that underrate r the higher ones as kicker, orion, alpine, rockford fosgate, hifonics...if you want an amp for your $ then go with the hifoncics because its cheap...and you get what they tell you the rating is for sure. |
