Home > Message Board > Car Audio > Amplifiers > Archive through April 17, 2006 > Need Help
Author Thread: Need Help
Username: Dtp12
I bought a used rockford fosgate 500a2 old skool
but when i tested it on my two solo barIc 10 L7 i culdnt hear any thump from my speakers the amp turn on just doesnt sound as loud as the 250a2 i had replaced it which rattled the speakers hard any sugestion?
Username: Dustin3
Tigard, Or
U.S.
Post Number: 760
is your gain set correctly or bass boost??
what are the specs on that amp?
Username: Dtp12
im fairly new to this car audio stuff just learning so how do i set the gain and whats it for since i bought it used its how the previous user had it and it doesnt have a bass boost built inside like my rf 250a2 it uses an external bass knob which was missing
here are the specs
710 watts mono into 4 load
330 watts per channel into a 2 load
210 watts per channel into a 4 load
and one other question i had an 8gauge power lead on my other system do i have go to 4gauge for it to perform better.
Username: Theelfkeeper
Stockbridge, GA
Post Number: 1731
4awg would be better.
don't use any bass boost. they usually just create distortion.
there should be a Gain or Input sensitivity knob on the amp. you need to find that and adjust it to match the Pre Out Voltage of your HU. or set your HU 3/4 of the way up, then adjust the Gain ont he amp till you start to hear distortion, then back it down a little and you're good to go.
might also check your filters. set it to low pass and 80Hz.
Home > Message Board > Car Audio > Amplifiers > Archive through April 17, 2006 > Need Help [ « Previous ] [ Next » ]
