Thread: 1000w 4ohms RMS amp |
New member Username: Hockeyknight
Post Number: 5 Registered: Apr-06
| Posted on Thursday, April 13, 2006 - 01:01 am: |
i need 1 as cheap as possible. any1 got any sugjestions?
Silver Member Username: Gage
Post Number: 158 Registered: Feb-06
| Posted on Thursday, April 13, 2006 - 01:03 am: |
jl 1000/1 pg 1200.1 not to many amps do 1000rms at 4 ohms |
Post Number: 7 Registered: Apr-06
| Posted on Thursday, April 13, 2006 - 01:16 am: |
well how do i power a 4ohms sub with an rms of 1000?? IM SOOO CONFUSED lol thanks fer the reply! |
Silver Member Username: Matt12490
Benicia,
California
Post Number: 665 Registered: May-05
| Posted on Thursday, April 13, 2006 - 03:55 am: |
you can also look into 2 channel amps that put out 1000w when bridged into a 4ohm load. |
Bronze Member Username: Akula_class
Post Number: 63 Registered: Feb-05
| Posted on Thursday, April 13, 2006 - 04:06 am: |
What is the name of your sub? |
Bronze Member Username: Hockeyknight
Post Number: 17 Registered: Apr-06
| Posted on Thursday, April 13, 2006 - 09:13 am: |
alpine type x |
Bronze Member Username: _jay_
Post Number: 63 Registered: Mar-06
| Posted on Thursday, April 13, 2006 - 10:51 am: |
make it into a 1ohm load... BXI2006D would be the ideal amplifier to use..well atleast that is what i use for my 2 type X's n' it works great even tho it could take more power..that amp works great. |
Post Number: 64 Registered: Mar-06
| Posted on Thursday, April 13, 2006 - 10:53 am: |
sorry for double post but if you only have 1 type X use the BXI1206D because then your putting out more then its rated for and the sub always wants more so you should be plenty happy with that amp. while running 1200 watts rms x 1ch @ 1 ohm |
Post Number: 19 Registered: Apr-06
| Posted on Friday, April 14, 2006 - 12:48 am: |
how do i make the type x into a 1ohms load |
Gold Member Username: Rzarector
Coquitlam,
Bc
Post Number: 1033 Registered: Dec-04
| Posted on Friday, April 14, 2006 - 01:07 am: |
you cant you can wire it at a 2ohm load or 8 ohms which is out of the question.. for 2 ohms you wire it the voice coils in parrallel pos to pos neg to neg |
Silver Member Username: Dustin3
Tigard,
Or
U.S.
Post Number: 764 Registered: Oct-05
| Posted on Friday, April 14, 2006 - 01:38 am: |
wait. do you have 2 dvc 4 ohm subs, or 1 dvc 2 ohm sub?? |
Tigard,
Or
U.S.
Post Number: 765 Registered: Oct-05
| Posted on Friday, April 14, 2006 - 01:39 am: |
and adam... use www.the12volt.com to find out how to wire your subs together. go to woofer wiring and then select the impediences and how many subs u have. |
Coquitlam,
Bc
Post Number: 1041 Registered: Dec-04
| Posted on Friday, April 14, 2006 - 01:59 am: |
i think he has 1.. type x's only come in dua 4 ohm config |
Tigard,
Or
U.S.
Post Number: 771 Registered: Oct-05
| Posted on Friday, April 14, 2006 - 02:11 am: |
so basically adam, you dont want an amp 1000 @ 4 ohms, but 1000 @ 2 ohms since 1 dvc 4 ohm sub cant wire to a 4 ohm load. www.the12volt.com (adam) |
Silver Member Username: N2audio
Lawrence,
Ks
Post Number: 798 Registered: Mar-04
| Posted on Friday, April 14, 2006 - 10:04 am: |
the "as cheap as possible" part makes it tough. There are several budget amps that are 1000w at 1 ohm but for some reason they're much less common at 2 ohms. PG has one in the Octane line that would work - 15.0:1 This would do a good job - http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14934 You might also check ebay for a JBL BP1200.1 |
Lawrence,
Ks
Post Number: 799 Registered: Mar-04
| Posted on Friday, April 14, 2006 - 10:06 am: |
Here's a refurb excelon for $200 http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=15611 |
