Thread: Rear speakers in a 96 civic,...2 door AHHHHH WTF? |
New member Username: Drift247
NY
Post Number: 3 Registered: Mar-06
| Posted on Friday, March 31, 2006 - 05:09 am: |
Hey all..i have to do rear speakers in a 96 civic 2 door,..i was thinking ok..easy..i was wrong.. WTF! what the hell.. how do you get them out? lol...i dont want to break anything on this car.Does everything need to come out? how does the back seats come out(the top part that flips down)? thanks |
Silver Member Username: Mrmikelazott
Independence,
Oregon
Post Number: 101 Registered: Dec-05
| Posted on Friday, March 31, 2006 - 06:23 am: |
go buy a haynes or chilton manual for your car. i have one for my 97 2 door neon, and it helped a million times over. told me exactly how to get the back seat off and how to get to the 6x9s in the back. |
Gold Member Username: Suleman36
Maryland
U.S.A.
Post Number: 3414 Registered: Feb-05
| Posted on Friday, March 31, 2006 - 04:08 pm: |
where do you get a haynes or chilton manual ? |
Gold Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 1618 Registered: Feb-05
| Posted on Friday, March 31, 2006 - 04:55 pm: |
any auto parts store. back seats should just be held in by 2 bolts on each side. are they in pod type deals, or covered flat by the rear deck?? |
Independence,
Oregon
Post Number: 102 Registered: Dec-05
| Posted on Friday, March 31, 2006 - 08:00 pm: |
the bottom part of the seats in my 2 door neon was just held on by snap things. and once you got the bottom part of the seat off, the two bolts were revealed. all i had to do was take out the two bolts and then pull the back part of the seat off. hope this helps. and yeah, any auto store. i got mine at autozone for like 10-12 bucks. |
