Home > Message Board > Car Audio > EQs and Crossovers > Archive through August 01, 2006 > Should i get one
Author Thread: Should i get one
Username: Gage
Post Number: 90
hi im wondering if i should get an eq i am interested in ty's just dont know what it would do for me is it worth it i have a premier 960 h/u
Username: Tjmutlow
Post Number: 1796
It will send more voltage to your amps, and it will make you turn the amps down, i have my amp less then 1/4 up. it is an intricate piece....
Username: Tjmutlow
Post Number: 1797
by the way, this was about 1100 new in a store..
Username: Kevin420
Gilbert, Az
Post Number: 9
definately worth it, some have gain adjustments on them. Like ty said, you can boost the gain before it reaches your amps. Kicker KQ5
Home > Message Board > Car Audio > EQs and Crossovers > Archive through August 01, 2006 > Should i get one [ « Previous ] [ Next » ]
