Home > Message Board > Car Audio > Speakers > Archive through April 04, 2006 > Im an absolute noob
Author Thread: Im an absolute noob
Username: Fistofmeat
Tucson, AZ
US
hello all, i need some help desperatly. i don't want anything that is awesome or anything. i just want some speakers and a cd player. as long as it works and sounds decent, i don't care. i was thinking about getting a pair of Roadmaster RS525 speakers and i just wanted to know if they work and if they produce decent sound. also, how are speaker sizes measured? thanx all
Tucson, AZ
US
also, (i forgot to ask before :P) does n e one know what size speakers are in a 1990 corolla 4dr sedan and if all the speakers are the same?
Username: Delsole
Post Number: 244
well speakers arent all the same size they come in many different sizes and you could possibly measure the speakers in your car instead of asking
as of a respones for the speakers you chose ive never heard them so i dont know
good luck hope i helped a little
Username: Mrmikelazott
Independence, Oregon
Post Number: 98
i have used the 6.5in version. they sound pretty good for about a month, then they die. i would strongly suggest getting something else. maybe some cheap pioneers, but definately not roadmaster.
http://www.cardomain.com/fit/TOYOTA/COROLLA
Tucson, AZ
US
what exactly am i measuring? the width of the brackets ont he speaker, or the diameter of the speaker itself?
and thnx for the link michael, it was helpful.
i dumped the idea of the roadmasters, and im going for some lightning audio ones instead. pioneers are out of my budget (yea i know im cheap) and the lightning audio are supposedly made by rockford... so they can't be all bad...
Username: Tjmutlow
Post Number: 1800
that car calls for 4"in top dash, or 5" in lower door, and 5.25 in rear deck....
Username: Solacedagony
New Jersey
US
Post Number: 860
Ahmed, check out Infinity, good for the money.
Roadmaster, Lightning Audio, etc = Walmart crap. You get can get a lot more for your money.
Home > Message Board > Car Audio > Speakers > Archive through April 04, 2006 > Im an absolute noob [ « Previous ] [ Next » ]
