Home > Message Board > Car Audio > EQs and Crossovers > What crossover should i get
Author Thread: What crossover should i get
Los Angeles, CA
Post Number: 3353
i need suggestions on a crossover. i am looking for one with front, rear, and sub input and output.
Relevant Product Info
Username: Kevin420
Gilbert, Az
Post Number: 11
KIcker kx3, like 80-100 on ebay, love mine. Good luck
Username: Maxsq
I have been around for many years in this business and if you want a good x-over for not a lot of money look up the Coustic XM-3e on ebay. It is very high quality even though most of the other coustic stuff is cheap. It was the x-over used in the show scene for quite a few years and are typically around 20-30 dollars now.
Username: Auroradrvr
Ft. Lauderdale, Florida
That Coustic XM-3e is just like my Clarion MCD-360. In fact, the cases are identical. Man, I could have saved 50 bux...
Username: Christogq
Does the XM4 work as good as the XM-3e? Does it change the sound quality if I don't have the bass knob with it?
Username: Glasswolf
Wisteria, Lane
Post Number: 11692
XM4 works just as well.
if you get a Coustic model with the "e" suffix, it adds the option of a wired remote knob.
Los Angeles, CA
Post Number: 11997
lol. glass you posted in my thread exactly 1 year later. thanks for the quick response. lol. jp man.
Username: Glasswolf
Wisteria, Lane
Post Number: 11869
wow, I did.
heh
sorry
Los Angeles, CA
Post Number: 12006
lol. its cool.
since you are here, let me ask you a question. whats a good xover to run a 3 way comp active?
Username: Glasswolf
Wisteria, Lane
Post Number: 11875
depends on your budget.
I went with the Pioneer P9 combo that offers the head unit and DSP unit with separate channels for an active system with integrated EQing etc..
its nice
Los Angeles, CA
Post Number: 12019
i bet it is.
no particular budget. i found a place i can get the dynaudio 340 for a good price. around 900ish. i want to keep everything in the stock place so that is why i want to go with the 340. well if i put everything in the stock place, i just need more control over the component set.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > EQs and Crossovers > What crossover should i get [ « Previous ] [ Next » ]
