Thread: CVR10 Sub and amp help |
New member Username: Ehowz
Post Number: 1 Registered: Mar-06
| Posted on Monday, March 27, 2006 - 04:35 pm: |
if i was to get one kicker CVR10 sub, should i get a 4ohm or a 2ohm sub? also, could i get some amp recommendations? |
Gold Member Username: Tjmutlow
Post Number: 1776 Registered: Sep-05
| Posted on Monday, March 27, 2006 - 05:04 pm: |
dual 2 if just 1 sub, then you can have either a 1ohm mono amp or a 2channel bridged on it. |
Silver Member Username: Themax96se
Post Number: 126 Registered: Jan-05
| Posted on Monday, March 27, 2006 - 07:29 pm: |
on a kicker CVR10 ? I dont know if they even have dual 2 ohm. Besides its only a 300 watt sub. |
Silver Member Username: Dustin3
Tigard,
Or
U.S.
Post Number: 661 Registered: Oct-05
| Posted on Monday, March 27, 2006 - 08:11 pm: |
"I dont know if they even have dual 2 ohm" WTF louie. what are you talking about. explain to my why they wouldnt have dual 2 ohm??????????? most all subs come in dual 4 ohm and dual 2 ohm, those are the most widely used configs. of course they have dual 2 ohm subs! i actually think they only come in dual 2 ohm and dual 4 ohm, so make sure you know wat your talking about before you post. "Besides its only a 300 watt sub" watts dont matter. more watts doesnt mean better sub or louder. some 300 rms subs get louder than 1000 watt. |
Tigard,
Or
U.S.
Post Number: 662 Registered: Oct-05
| Posted on Monday, March 27, 2006 - 08:14 pm: |
and evan, it doesnt matter what kind of sub(s) you get. dvc 2 ohm and 4 ohm, it your choice. The only difference between them is that you present a certain load on the amplfier with each one. so find an amp that you would want, and we will tell you what sub to get... |
Silver Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 289 Registered: Dec-05
| Posted on Monday, March 27, 2006 - 08:17 pm: |
jjajaja dang bassman you got pissed! |
Post Number: 4 Registered: Mar-06
| Posted on Monday, March 27, 2006 - 08:50 pm: |
thanks for the help, i think i can take it from here. |
Tigard,
Or
U.S.
Post Number: 665 Registered: Oct-05
| Posted on Monday, March 27, 2006 - 09:01 pm: |
lol. i didnt mean for it to sound mean, honestly. i was just telling him to make sure he knows what hes talking about. so i really wasnt pissed. sry if i came out to sound like that. just gettin the facts straight JULIOB. lol |
Post Number: 132 Registered: Jan-05
| Posted on Monday, March 27, 2006 - 11:55 pm: |
hah, was kinda funny. What I was saying is that, at least from what I've noticed... on smaller, less powerful subs, the more common config. is a 4ohm SVC or 4ohm DVC. Although I do have the older Type R 10" that is 2ohm DVC, and thats only 300RMS. Either way, your recommendation is for a 1 ohm load @ 300RMS... do you really think this is the best config when looking for a matching amp? I would say the 4ohm DVC would be better. What 1ohm mono amp do you recommend thats 300RMS? Thats WTF I'm talking about. |
