Home > Message Board > Car Audio > Security Systems > Archive through December 02, 2004 > Autopage rs850 pager alarm problems
Author Thread: Autopage rs850 pager alarm problems
Username: Pmtyrka
Decatur, Al
I need some expert help. After installing my security system, which seems to be working fine, my dash board air bag light stays on and the turn signals stopped working and the fan a/c system does not work. All the fuses are o.k. but it seems as if there is no power going to these things. Everything else such as lights, wipers, defroster etc. all work fine. I am stumped-help.
Username: Erus37
Hollywood, Fl
Post Number: 13
YOUR LIGHT IS ON BECAUSE EITHER YOU CUT INTO OR SPLICED INTO THE YELLOW COATED WIRE UNDER THE DASH OR CUT THE AIRBAG WIRE.
YOU HAVE SOME CUT WIRES SOMEWHERE IN YOUR VEHICLE
WHAT YEAR, MODEL, MAKE IS YOUR VEHICLE I'LL GIVE YOU THE WIRING DIAGRAM FOR IT
Username: Ltng_fst
Chesapeake, VA
I just got this same alarm w/ remote start hooked up by a car audio shop and the radio stays on after I turn off the truck. I called the shop back and they said they can't look at it until Tuesday. Anybody got any ideas?
PS sorry to bring up such an old topic.
Username: Ltng_fst
Chesapeake, VA
Going in the morning. Anybody got any ideas?
Username: Ltng_fst
Chesapeake, VA
They had one of the wires hooked up that wasn't supposed to be. Accessory or something. Nobody seems to give a s--t anyway.
Home > Message Board > Car Audio > Security Systems > Archive through December 02, 2004 > Autopage rs850 pager alarm problems [ « Previous ] [ Next » ]
