Thread: 4 4" speakers needed, What kind? |
Bronze Member Username: Northomaha
Post Number: 13 Registered: Mar-06
| Posted on Sunday, March 26, 2006 - 10:34 pm: |
I have an 87 Range Rover and the only speakers you can fit in the stock holes are 4". I need some good speakers that will run off the head unit with minimal distortion. Also I was thinking about getting two 6x9s and can I wire the amp to power them in a series with my two subwoofer amps? or do they have to be in some way connected with the head unit other than the RCA outputs? Thanks |
Gold Member Username: Chaunb3400
Huntsville,
Alabama
U.S.
Post Number: 6329 Registered: Jul-05
| Posted on Monday, March 27, 2006 - 03:45 am: |
Infinity refrences btw: I have 2 almost new 4" Infinty refereces for sell, $25 +shipping |
Silver Member Username: Alteraudiousa
Concord
Post Number: 510 Registered: Jan-06
| Posted on Monday, March 27, 2006 - 09:29 am: |
get one set of CDT CL-4x coaxials and one set of CL-4 midrange woofers. If you're adding in 6x9s, CL-69 midrange woofer to add some bass for the bottom end for you. |
