Thread: Do I Really need to upgrade my 6 1/2's? |
New member Username: Raff24
Post Number: 1 Registered: Mar-06
| Posted on Sunday, March 26, 2006 - 08:35 pm: |
My buddy has an 01' Volvo S60 with a really good stock stereo. He has stock 6 1/2's all the way around and wanted to amp his speakers to get more clarity at higher volume.. The best buy guy told us to upgrade our stock speakers or the amp will blow them out...The stock speakers are really good..Do i really need to replace them?? Thank you. |
Silver Member Username: Ruthless06
C-ville,
Va
Post Number: 126 Registered: Feb-06
| Posted on Sunday, March 26, 2006 - 09:02 pm: |
you can't amp stock speakers lol. unless they are are rated at a higher wattage then what the factory amp or hu is putting out. then maybe, not a definate. |
Silver Member Username: Alteraudiousa
Concord
Post Number: 499 Registered: Jan-06
| Posted on Sunday, March 26, 2006 - 09:20 pm: |
yep you do, almost any aftermarket amp will put out more than the factory amp. Just get new ones. |
New member Username: Van_man
Post Number: 7 Registered: Mar-06
| Posted on Sunday, March 26, 2006 - 10:56 pm: |
I am running my stock 6x9 in the door with 170w amp and they are taking it so far. They are shaking the whole door and the gain is set @3/4. I was going to replace them but tried the amp first, and if they smoked then I would replace them. I say try it with the amp but dont max the gain, but plan on new speakers anyway...Personal I am waiting for mine to cook first. |
Gold Member Username: Tjmutlow
Post Number: 1766 Registered: Sep-05
| Posted on Monday, March 27, 2006 - 04:08 am: |
I would upgrade the speakers with an amp and keep the factory speaks,so if you sell or trade in the car... |
Silver Member Username: Solacedagony
New Jersey
US
Post Number: 849 Registered: Oct-04
| Posted on Monday, March 27, 2006 - 08:21 am: |
You can amp any speaker, you just need to make sure you're not sending more continuous Wattage than your stock speaker can handle. In fact, they should sound much better on top of that. 6.5s will get loud and distort at a later time, the 6x9s will get louder, but distort earlier. |
