Home > Message Board > Car Audio > Amplifiers > Archive through March 28, 2006 > Looking for a small mono block
Author Thread: Looking for a small mono block
Username: Homercleeze
able to put out 400/1 and fit into a space nine inches high and 15 inches wide....depth isnt an issue, anyone got any suggestions on what would fit?
Username: Ctmike
Ct.
Post Number: 108
i'd get this, i have two and love them:
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14130
that would be perfect, except that 10.6 inches tall is slightly bigger than what i have to work with. still i appreciate the reply. to try to put this in perspective, this amp is for a box built to sit on a pallet jack that needs to be hooked to a converter, i have exactly 10 inches in height underneath the head unit to mount the amp next to the AC/DC converter. i have 14-18 inches of width to use next to the converter on the back of the box.
Username: Matt12490
Benicia, California
Post Number: 460
is ebay an option?
Username: Matt12490
Benicia, California
Post Number: 461
if so...
http://cgi.ebay.com/ebaymotors/MTX-421D-CAR-AUDIO-AMP-AMPLIFIER-420W-CLASS-D_W0Q QcmdZViewItemQQcategoryZ38638QQitemZ8048338249QQrdZ1QQsspagenameZWDVW
Username: Matt12490
Benicia, California
Post Number: 462
or...
http://cgi.ebay.com/MTX-AMPLIFIER-400-WATTS-CLASS-D-MONO-FREE-SHIPPING_W0QQitemZ 9702138018QQcategoryZ39735QQrdZ1QQcmdZViewItem
Username: Nanbakat
Mexico City
Mexico
Post Number: 19
The most compact amps on the market are the new PDX series amps by alpine. You can see pictures of them on Crutchfield's website. They supposedly go on sale early next month.
These amps are designed to be stacked so you need zero clearance around the sides.
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 286
Directed 600x1 , depends how are you going to wire it
Username: Tjmutlow
Post Number: 1762
if depth is not an issue, you can turn an amp sideways......and the JL 250/1 is a nice amp, i have it on a 12w3 and the gain is turned way down on it.
Home > Message Board > Car Audio > Amplifiers > Archive through March 28, 2006 > Looking for a small mono block [ « Previous ] [ Next » ]
