Thread: Need help with my system. |
New member Username: W0ntonjai
Post Number: 1 Registered: Mar-06
| Posted on Sunday, March 26, 2006 - 05:16 am: |
HI i am having problems with mt MTX Thunder 342 amp hooked up to a 12" Xplod sub. the amp is connected using a 4ga power ofc cable straight to the battery with a 60 amp stinger fuse. The amp constantly turns off after about 5 minute intervals and turns back on . could it be overcurrent, over heating. the amps problem, the wiring, how cani fix this? thank you |
Silver Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 284 Registered: Dec-05
| Posted on Sunday, March 26, 2006 - 05:22 am: |
RMS on amp and subs |
Gold Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 1522 Registered: Feb-05
| Posted on Sunday, March 26, 2006 - 05:36 am: |
sounds like you either have the impedance too low. check how the sub is wired. or 4awg might not be big enough...idk the output on that amp, but a cony Xplode can't take that much power so i doubt its that. maby gains are set too high. |
Post Number: 3 Registered: Mar-06
| Posted on Sunday, March 26, 2006 - 05:43 am: |
the Rms on the sub is 350 watts. and the amp is MTX Thunder 342 85W x 2 Channel Amplifier 340 watts RMS |
Post Number: 4 Registered: Mar-06
| Posted on Sunday, March 26, 2006 - 05:54 am: |
i might be changing my amp to a hifonics ZX6000 zeus series runniong at 600 rms at 4ohm bridged, but that hoping that it may fix my problem, but i doubt it. |
Post Number: 5 Registered: Mar-06
| Posted on Sunday, March 26, 2006 - 05:58 am: |
the sub was bridged. the power is connected straight tot he battery, the ground is on a metal that is a part of the chasis, i didnt sand it off but there was no paint and it was clean. My car is a 1999 Honda CRV if that helps. What am i supposed to be looking for specifically. I tried setting the frequencies and the gains to lowest highest all medium , yet the same outcome. Any more sugestions? |
Post Number: 6 Registered: Mar-06
| Posted on Sunday, March 26, 2006 - 06:00 am: |
ne more thing it lasts the longest after it has been cooled overnight or atelast a few hours. |
