Thread: Hifonics |
Silver Member Username: Delsole
Post Number: 236 Registered: Feb-05
| Posted on Saturday, March 25, 2006 - 08:09 pm: |
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=15722 how wuld this poew 2 jlw6v2's compared to a jl 1000/1 would it sound as good |
Post Number: 237 Registered: Feb-05
| Posted on Saturday, March 25, 2006 - 08:11 pm: |
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=15722 how would this power 2 jlw6v2's compared to a jl 1000/1 would it sound as good typo |
Silver Member Username: N2audio
Lawrence,
Ks
Post Number: 749 Registered: Mar-04
| Posted on Monday, March 27, 2006 - 10:41 am: |
just as good - better considering the JL isn't supposed to be run below 1.5 nom. Be careful with the gains. You'll have more power available than the subs need. Avoid clipping and it should be a loud, good sounding combo - assuming the enclosure's quality. |
Gold Member Username: Carguy
Post Number: 5417 Registered: Nov-04
| Posted on Monday, March 27, 2006 - 11:21 am: |
There's a reason why that amp is priced much lower than JL. |
Silver Member Username: Rustysurfer916
Oviedo,
FL
Post Number: 129 Registered: Mar-06
| Posted on Monday, March 27, 2006 - 11:55 am: |
dude if you got the money for JL subs then stick with the JL amp |
Gold Member Username: Chaunb3400
Huntsville,
Alabama
U.S.
Post Number: 6340 Registered: Jul-05
| Posted on Monday, March 27, 2006 - 12:03 pm: |
Hey Isaac i heard a 12w7 in a ho box the other day, and i no u are always talking about it, and it was one of the best bass expeiences i have ever heard with 1 12" sub, simply amazing, loud and clear, hit ever note, very accurate, just crazy how it sounded........I use to think jl was over priced, but now i see what ur actually buying, some of the best car audio equipment there is... |
Post Number: 5419 Registered: Nov-04
| Posted on Monday, March 27, 2006 - 01:02 pm: |
Congratulations. The 10W7 in HO box will also surprise you. |
