Home > Message Board > Car Audio > Amplifiers > Archive through March 28, 2006 > Hifonics generation xx hercules question
Author Thread: Hifonics generation xx hercules question
Username: Cocizzie
i have this amp and it is rated at 2000 rms@1ohm and 1600 rms @2 ohms. my question is what woofers would anyone suggest to run with this amp? i want great spl woofer with good sq i can pay 600 to 700 for a pair.all suggestion will be appreciated
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 277
two arsenals 12
Username: Theelfkeeper
Stockbridge, GA
Post Number: 1505
might be better to post this in the Sub section.
may be too much for a set of Arsenals, i don't know though, maby 2 havocs.
what are you looking for?? Sound Quality, just something loud as hell or a good mix?? also, do you have the electrical system to handle that kinda power??
Username: Cocizzie
im looking for a mix of sound quality and something that hit hard as hell.ive never heard of havocs or arsenals where can i get them from?
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 283
Brandon, that amp should be pushing 1800w at 1 ohm, arsenals can hold 900 each don't you think ?
of course you can get different subs man, ask to chauncey or rovin
Home > Message Board > Car Audio > Amplifiers > Archive through March 28, 2006 > Hifonics generation xx hercules question [ « Previous ] [ Next » ]
