Home > Message Board > Car Audio > Amplifiers > Archive through March 28, 2006 > HELP!!!!!!!
Author Thread: HELP!!!!!!!
Username: Cellini
Burlington, Wa
U.s.
Im having trouble with this amp here
http://cgi.ebay.com/PERFORMANCE-TEKNIQUE-1200W-MONOBLOCK-MONO-AMPLIFIER-AMP_W0QQ itemZ9703319307QQcategoryZ18797QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
The protection light keeps coming on. i have it wired putting out a 2 ohm load to a performance teknique 12in 4ohm dvc 1000 watt sub. it will play at a very low volume but if you turn it up it will cut out very quickly. can anybody give me any advice????
Username: Theelfkeeper
Stockbridge, GA
Post Number: 1501
check your gains, grounds, wire size, voltage when it cutts off...
Username: W0ntonjai
how can you check the voltage?
Username: Sweatyogre
PA
Post Number: 16
Volt meter
Username: Cellini
Burlington, Wa
U.s.
What would i be looking for when im checking the voltage when it cuts out?
Username: Cellini
Burlington, Wa
U.s.
Ok, i think the problem was my ground. I've switched it around about 3 times and my stereo has played stronger each time. where would the ideal place be for me to ground my amp? do i need to scuff the paint off where i hook my ground to so it will conduct better? and will a good ground effect the ohm load my amp can handle in any way because it says its stable at 2ohms but it go's into protection when i wire it that way.
Username: Cellini
Burlington, Wa
U.s.
Home > Message Board > Car Audio > Amplifiers > Archive through March 28, 2006 > HELP!!!!!!! [ « Previous ] [ Next » ]
