Thread: Is this GOOD?? |
Silver Member Username: Nypdlapd
Post Number: 149 Registered: Feb-06
| Posted on Saturday, March 25, 2006 - 01:03 am: |
1 x 600W Rms @ 4ohm 1 x 900W Rms @ 2ohm 1 x 1200W Max @ 2ohm Class AB Circuitry 0-18dB Variable Bass Boost 200mV -8V RCA Voltage Input S/N >90dB 24dB 40-250 Hz Variable LP & HP Filter Tri-Mode Capable 2 Ohm Stereo, 4 Ohm Mono Stable 24dB 20-50Hz Variable Subsonic Filter High and Low Level Inputs 0.05% THD Remote Bass Control Thermal Short and Overload Protection RCA Line Outputs Built in Cooling Fan ITS ONLY 95.00 dollars Should i get it?? |
Silver Member Username: Tafkam
Texas
Post Number: 273 Registered: Apr-04
| Posted on Saturday, March 25, 2006 - 01:14 am: |
I am no expert at all but as you probably already know if you pay 95 bucks for an amp then you get 95 bucks worth of amp. Not that the more expensive it is the better it is but you do have to take it into consideration. I have had some folks on here give me the business about my Hifonics amps but I dunno about something that is less than a hundred bucks, seems too good to be true to me. Just my opionion don't take it as gospil............ Mike |
Gold Member Username: Southernrebel
Monroe,
Louisiana
Post Number: 2553 Registered: Mar-04
| Posted on Saturday, March 25, 2006 - 01:15 am: |
ummm...i'll put it this way: -i wouldnt pay $50 shipped for that amp. |
Post Number: 150 Registered: Feb-06
| Posted on Saturday, March 25, 2006 - 01:38 am: |
y??Its used my friend only used it for 3 weeks |
Silver Member Username: N2audio
Lawrence,
Ks
Post Number: 750 Registered: Mar-04
| Posted on Monday, March 27, 2006 - 10:47 am: |
Visonik's built a lot of respectable mono amps. If I were guessing I'd say it's in the same category as the 'Bahn 8000t which has been pretty popular as an 800w budget amp. For $95 I'd say it's worth a try. |
