Thread: How to push the full 900 out of this amp? |
Bronze Member Username: Dj_excite
Post Number: 38 Registered: May-04
| Posted on Friday, March 24, 2006 - 06:49 pm: |
how would i push a full 900 watts out of this amp or close to the max without damaging anything http://cgi.ebay.com/Lightning-Audio-900-Watt-Amplifier-LA1-300-2-RemoteNo_W0QQit emZ9700735399QQcategoryZ39744QQrdZ1QQcmdZViewItem |
Silver Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 274 Registered: Dec-05
| Posted on Friday, March 24, 2006 - 06:51 pm: |
WELL NOOB FYI THAT AMP IS 300 RMS SO WHAT YOU CAN GET IS GET 2 KICKER COMPS, THE OLDER ONES THAT ARE 125/150 RMS AND BUY THE 4 OHM VERSION AND THEN WIRE THEM TO CREATE A 2 OHM LOAD. THAT'S THE BEST SYSTEM YOU CAN GET WITH THAT LITTLE AMP |
Post Number: 39 Registered: May-04
| Posted on Friday, March 24, 2006 - 07:02 pm: |
im not too much of a noob...the amps description sais 900...i am thinking the same..prob can get 600 max out of this amp i got it for free so i really dont giv a sh** |
Bronze Member Username: Rustysurfer916
Oviedo,
FL
Post Number: 98 Registered: Mar-06
| Posted on Friday, March 24, 2006 - 07:48 pm: |
lightning audio suxass your not gettin more than 300 out of that amp |
Gold Member Username: Tjmutlow
Post Number: 1749 Registered: Sep-05
| Posted on Friday, March 24, 2006 - 08:02 pm: |
youll never see 900, and normally max power is at 4ohm bridged, or 2ohm stero, those numbers do not match up. |
Post Number: 43 Registered: May-04
| Posted on Friday, March 24, 2006 - 09:16 pm: |
yea thats what im saying...the dam lightning audio bookt that came with the dam amp states 900..not possible. thank you pplz |
