Home > Message Board > Car Audio > Amplifiers > Archive through March 28, 2006 > Kicker ZR series
Author Thread: Kicker ZR series
Username: Niteshift76
I have three 10's single coil 4ohm running mono on kicker ZR amp when volumn is turned up past 16 the subs fade out and come back on , but amp never goes into protection mode???
Username: Rwells
Atlanta, Georgia
United States
Post Number: 19
what kind of subs?
rockford p1 10" 150/300 watt 4ohm
Username: Theelfkeeper
Stockbridge, GA
Post Number: 1491
sounds like a power issue.
do you have an upgraded electrical system??
large enough Gauge of wire??
good grounds??
I have 4 gauge wire power and ground..1000 cranking amp battery ..ground is off the frame???
I also have a cap on the system
Post Number: 7
Also the read out on the cap changes alot from 14.6 to 11.9 and everything in between
Post Number: 10
any other ideas???????
Home > Message Board > Car Audio > Amplifiers > Archive through March 28, 2006 > Kicker ZR series [ « Previous ] [ Next » ]
