Home > Message Board > Car Audio > Amplifiers > Archive through March 28, 2006 > Trunk pops open
Author Thread: Trunk pops open
Username: Pavooked
Detroit, Mi
United States
Post Number: 7
having problem with trunk poping open when playing my music. trunk latch looks ok could it be somthing electrical? or maybe just bad latch soon as i turn it up it pops open could i disconnect somthing to stop this? has anyone had this problem?
Username: Southernrebel
Monroe, Louisiana
Post Number: 2539
prolly just a bad latch.
Username: B101
Queen City, NC
Post Number: 2053
could be a bad relay, is it fully electrical?
Username: Pavooked
Detroit, Mi
United States
Post Number: 8
yes fully electrical
Username: B101
Queen City, NC
Post Number: 2054
lol, check the relay then, faulty relay will do that.. Ive had that problem too..
what kinda car is it?
Username: Pavooked
Detroit, Mi
United States
Post Number: 10
you think it would help if disconnect and just use key to open trunk?
Username: Pavooked
Detroit, Mi
United States
Post Number: 11
dodge intrepid R/T
Username: B101
Queen City, NC
Post Number: 2055
yea, u can simply go into the trunk, and unclip the wire harness from the latch, that way relay dont send false info! You will need to use the key... thats what I do anyway, cause my equipment is in the trunk!
Username: Pavooked
Detroit, Mi
United States
Post Number: 12
cool i'll try it thanks
Home > Message Board > Car Audio > Amplifiers > Archive through March 28, 2006 > Trunk pops open [ « Previous ] [ Next » ]
