Home > Message Board > Car Audio > Amplifiers > Archive through March 28, 2006 > Needing alot of help with amps?PLS HE...
Author Thread: Needing alot of help with amps?PLS HELP EXPERTS
Username: _jay_
Post Number: 25
well i am wondering with my 2 swx-1242D amps i only have 150-250$ to spend on an amp... i was told 2 get an orion 2500d..but thats only a mono amp..i was wondering if i bridged my 2 subs together..single they r 500-1,000rms@4ohms ea...if i bridge them to 1 amp into a 4 ohm load....could i get an amp that i can have mono n' run it into it at 2,000watts?? as a 4ohm load n' 1 channel..i totlay lost...noobie..sorry confused...help pls
Username: Tjmutlow
Post Number: 1745
for the right amp you need to save and get the 2500d, you can find them on ebay for anywher from 275 and up.
Username: _jay_
Post Number: 26
hmm more options?? and sum1 help me out w\ the 1 channel shizzit..since its 2 subs why would i get a 1 channel?
Username: Tjmutlow
Post Number: 1748
because those are dual 4ohm subs and you either need a strong 2 channel and run stero or a mono 1ohm amp, and you prob are not going to find a good one for 250
Username: _jay_
Post Number: 27
LA2038
MXA282
one of those do it??
Username: Skidoo32
ok i have a 94 pontiac grand am and i was wondering how to hook up my system to the stock cd player?
Username: _jay_
Post Number: 28
take it right from the speakers...just take a line right from their or take apart ur dash n' have sum fun..
Username: Tjmutlow
Post Number: 1754
I doubt very seriously that those amps will make those move...
Username: Chaunb3400
Huntsville, Alabama
U.S.
Post Number: 6286
where those subs givin to u, because no way ur gonna pay 500 for sum subs and cant even afford to power them
Really look into Hifonics amps cheap power, kinda overrated (rms wise) but they will get the job done
Username: Dustin3
Tigard, Or
U.S.
Post Number: 637
usually jay, for 2 subs you get a mono amp, 1 sub = 2 channel, speakers = 4 channel. its kinda like backwards.
Huntsville, Alabama
U.S.
Post Number: 6288
"1 sub=2 channel"
WTF
Read
http://wickedcases.com/caraudio/amplifiers.html
Username: Dustin3
Tigard, Or
U.S.
Post Number: 644
i know. i have read that chaunc. most setups i see, even on this site people with 1 sub usually has a 2-channel amp. i am just saying what i have seen on this site. it doesnt really matter though, 2-channel or mono, you just plain out need an amp that puts out the power you need and can connect the the sub(s).
also, chanc, dont take the iraq thing personal, its just a basic debate that i think is very good. just a debate, dont have anything against you.
Username: _jay_
Post Number: 29
hmm...so would i be better off in price wise going on a mono amp and going at a 4ohm load, then getting a high quality compacitor lyke a 5 or 6 frag?
JaY
Username: Rovin
Trinidad & T...
Post Number: 6870
Jay - u sound like an absolute Newb - i suggest that u THOROUGHLY read
http://wickedcases.com/tutorials/index.html
www.bcae1.com
www.the12volt.com
Then come back here .....
Username: Redliner
Wilmington, Ma
Post Number: 1146
jay its a capacitor and they are measured in farads and one will not help you i agree with rovin go read those please
Username: _jay_
Post Number: 30
oook? so if i bridge the 2 subs, how many watts should it be lyke 2,000watts RMS x1@4ohm load
-JaY
Username: Dustin3
Tigard, Or
U.S.
Post Number: 650
jay, you should really read the sites. everyone starts as a newb and everyone has basically read top to bottom of those site's. just read and if u still have qestions, come back
and u dont need a cap. more strain on alt. not worth it
Username: _jay_
Post Number: 31
ook i've read it but i'm still at what i was in the first place..lol o well...i'm just wondering if that set up would work bridging would it be 2,000watts?@4ohm
Huntsville, Alabama
U.S.
Post Number: 6317
bassman3, i never looked at the thread after i posted the 1st time.lol, so no harm no foul.lol
Username: _jay_
Post Number: 32
i was told to get 2...profile AP1040
Username: Sandrew
i have a pioneer 1000w mono clas amp i am running two dual coil kenwood subs but it isnt very good please tell me why
Username: Sandrew
help me please
Huntsville, Alabama
U.S.
Post Number: 6331
do u have everything hooked up right
and if so it could be that ur stuff really isn't that good
Username: Sandrew
yeah its hooked up ight, the amps a good one but got the subs cheap $250 eavh at autobarn is a mono amp good 1000w??
Username: Sandrew
the amp is the best autobarn sell it a car audio shop, a 1000w mono should pump ay?
Username: Tjmutlow
Post Number: 1768
what is the ohm load on the amp, if it is the gm-d510 amp your either getting less then 600w@4ohms or the amp is down to a 1ohm load and your going to blow it up, and subs could be out of phase...
Username: Sandrew
what do u mean out of fase??? it is pioneer gm_d510m is it a goody??? how do i fix
Username: Sandrew
Post Number: 7
Pioneer
GM-D510M 1000w MONO Class D Amplifier
Peak Music Power: 1000 Watts
Number of Channels: 1
Load Impedance Capability: 2 ~ 8 Ohm (Mono)
Continuous Power: (4 ohm) 300W x 1
Continuous Power: (2 ohm) 600W x 1
Frequency Response: 20 ~ 240Hz
Total Harmonic Distortion: 0.03%
Signal-to-Noise Ratio: 100dB
Dimensions: 10-3/16" x 2-1/16" x 9-13/16"
thats the info on it
Username: Sandrew
Post Number: 8
do i need to get 2ohm sub????? can u get 2 ohm subs?????
Username: Young_james
Post Number: 1096
what VC config are you subs now?
Username: Tjmutlow
Post Number: 1773
get a beeter amp, pioneer is not know for there amps, get a 1ohm stable amp, like a directed or orion, kicker, etc..
Username: _jay_
Post Number: 33
mind not flamin my post with other peoples posts......keep 2 meh topic pls...
Home > Message Board > Car Audio > Amplifiers > Archive through March 28, 2006 > Needing alot of help with amps?PLS HE... [ « Previous ] [ Next » ]
