Home > Message Board > Car Audio > Amplifiers > Archive through March 28, 2006 > Amps to Power Treo Subs
Author Thread: Amps to Power Treo Subs
Username: Northomaha
Post Number: 10
I am looking to power two Treo 15.44" TSX Subs with 2ohm dvc. They are rated at 500 watts RMS each. I know they can be a little bit overpowered. I'm wondering what to go with as far as amps.
2 of these maybe?
http://www.ikesound.com/product-product_id/3783
or maybe one of these?
http://www.ikesound.com/product-product_id/3444
I'm leaning towards the two MA audio amps but Im here to get suggestions, any other amp options would be greatly appreciated.
Thanks
Username: James1115
Ct
Post Number: 5392
jl 1000/1 if you have the cash:-)
Username: Theelfkeeper
Stockbridge, GA
Post Number: 1481
i don't know much about MA audio's amps, but do know hifonics are good budget amps. don't push all they say, but are decient.
i'd definally reccomend the JL 1000/1 that James mentioned. also look at kicker and orion.
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 262
go with alpine
Post Number: 11
so the jl 1000/1 can push those two with no trouble?
Username: James1115
Ct
Post Number: 5401
in it's sleep:-)
Home > Message Board > Car Audio > Amplifiers > Archive through March 28, 2006 > Amps to Power Treo Subs [ « Previous ] [ Next » ]
