Home > Message Board > Car Audio > Amplifiers > Archive through March 28, 2006 > CAN ANY ONE HELP
Author Thread: CAN ANY ONE HELP
Username: Pavooked
Detroit, Mi
United States
ALT IS SENDING TO MANY VOLTS TO AMP SENDING 16VOLTS CAUSING AMP TO GO INTO PROTECTION IS THERE ANYTHING I COULD DO BESIDES BUYING NEW ALT?
Username: Joesmith1
Snellville, Ga
do you have a capacitor? it may help direct some of the volts away and keep it from going into protection. idk just a thought.
Username: Theelfkeeper
Stockbridge, GA
Post Number: 1483
what kind of amp?? and your charging system shouldn't be putting out that high a voltage. 15.8 is like max before you will screw stuff up.
Username: Pavooked
Detroit, Mi
United States
amp kx1200.1 2-SL512 subs the guy at car tunes said the same thing he never seen anything like it. said might be bad voltage regulater in alt.do you think it's wise to disconnect the amp? it works when the lights,heat and defrost is on. joe smeezy i have two caps .
Home > Message Board > Car Audio > Amplifiers > Archive through March 28, 2006 > CAN ANY ONE HELP [ « Previous ] [ Next » ]
