Thread: Alpine MRD-m1005 @1ohm |
New member Username: Rwells
Post Number: 8 Registered: Mar-06
| Posted on Thursday, March 23, 2006 - 09:59 am: |
i just bought an alpine mrd-m1005. but i realized its not gonna be enough power for my kickerCVR's. what do you think would happen if i run it at 1ohm? |
Gold Member Username: Rovin
Trinidad & T...
Post Number: 6839 Registered: Jul-05
| Posted on Thursday, March 23, 2006 - 10:36 am: |
prolly go into protection mode i'd guess . u risk damaging it .... |
Gold Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 1484 Registered: Feb-05
| Posted on Thursday, March 23, 2006 - 09:55 pm: |
i wouldn't try it, alpine amps aren't that great IMO. |
Bronze Member Username: Rwells
Post Number: 14 Registered: Mar-06
| Posted on Thursday, March 23, 2006 - 10:49 pm: |
IMO? well heres the deal!! i have 2 kickerCVR's (dual 4ohm). i need 800rms total. my alpine says it will give 700@14.4 volts @4ohms. when i turn on the amp it reads anywhere from 14.2 to 14.6 volts. so runnin with that voltage, i should get the full 700w RIGHT??? and with that being 350rms to each sub, it should pound pretty hard right?? |
Gold Member Username: Tjmutlow
Post Number: 1744 Registered: Sep-05
| Posted on Friday, March 24, 2006 - 06:33 am: |
you should be fine with that amp, and do not run it below 2ohms.. |
