Home > Message Board > Car Audio > Multimedia Systems > Archive through February 06, 2007 > What color is Parking wire Kenwood K...
Author Thread: What color is Parking wire Kenwood KVT-715/KVT-717
Username: Krazeelilkilla
I have a kenwood KVT-715DVD, i lost the manual and do not know what color the wire i have to connect to the parking brake is. I also don't know if it's the extra one on the head unit or the hide away unit?!? plz help
Username: Ironslave
Offutt AFB, Nebraska
U.S.A.
Post Number: 370
dont know if this will help but the wire on my clarion dvd is "grass green" according to the manual.
Username: Mattyb777
Couldnt find the KVT-715dvd on the Kenwood website, but looked at the other units and they all use the Green for the Parking sensor... Hope this helps
Username: Leew
Ketchikan, ALASKA
Post Number: 422
its green wire
Username: Ray_z71
My kvt-817DVD has a green wire and the display is visible when grounded.
Username: Dkchillin
Vermont
Post Number: 339
My kvt-617DVD also uses a green wire.
Home > Message Board > Car Audio > Multimedia Systems > Archive through February 06, 2007 > What color is Parking wire Kenwood K... [ « Previous ] [ Next » ]
