Home > Message Board > Car Audio > Amplifiers > Archive through March 28, 2006 > Wiring Configuration
Author Thread: Wiring Configuration
Username: Ndfantp
Hello
I recently purchased another Subwoofer to go with the one I owned previously. After installing it I found out that my Amp is not powerful enough to drive both at the levels I want it. I purchased the following amp, but due to the power on it I need to know whether I should wire the subs in series or parralel. I am fairly sure I can wire it in series but due to the size on the amp I don't want to blow the subs. Any help would be great. I already checked the 12volt.com but I just wanted some reassurance from some experienced people.
KENWOOD KAC-9152D
1800W Mono Ultra Efficient Class D
Power Amplifier with Remote
1,800 Watts max power
500 Watts x 1 max (4 ohms) RMS
900 Watts x 1 (2 ohms) RMS
900 Watts x 1 (1 ohms) RMS
Wired remote control to adjust boost level and frequency included
Dual mono drive' configuration option (requires two KAC-9152D amplifiers & specialist knowledge!)
Aluminium die-cast heat sink
Detachable aluminium top cover
All connections on one side for easy multi-amplifier installations
Built-in Variable Low-pass Filter 50-200Hz (24dB/oct)
Built-in Infrasonic Filter 15Hz/25Hz (18dB/oct) to cut unwanted ultra-low frequencies
Kenwood logo triangle' design power indicator LED
1 ohm stable
Gold plated RCA line input & line output terminals
Speaker level input option. RCA line outputs
Ultra Efficient Class D Circuitry
MOSFET Power Supply
1 Ohm Stable
Torroidal Noise Suppression Filter
Copper EE Core Power Transformer
Dual Secondary Capacitors
Ground Isolation Input Circuit
Detachable Aluminum Dress Plate & Top Panel Control
Die-Cast Aluminum Heat Sink
Variable (50 - 200 Hz) 18 dB / Octave Low-Pass Crossover
Switchable (Off / 15 / 25 Hz) 18 dB / Octave Subsonic Filter
Gold-Plated Preamp Inputs and Outputs
High and Low Level Inputs
2 Ohms Mono Stable
Red Triangle Power Indicator
Gold-Plated Screw-Type Power and Speaker Terminals
Remote Variable (0-18 dB) Bass Boost at 40-100 Hz
Single-Side Terminal Placement for Cleaner Installation and Improved Wire Management
I have 2 of these subs.
PIONEER TS-W306C
12" 1000W Max Subwoofer
Maximum Music Power 1000w
Nominal Power 400w
Impedance 4 ohms
Composite IMPP Cone Using Interlaced Aramid Fiber
Dual Mass High Power Magnet (83oz)
3-Layer, Fiber Woven Radial Surround
Extended Excursion Design
Thanks in advance for your help.
Tony
Username: Chaunb3400
Huntsville, Alabama
U.S.
Post Number: 6264
Parallel, would work fine, what amp did u have b4
Username: Tjmutlow
Post Number: 1736
its fine, adjust gain accordingly
Username: Ndfantp
I had a Pioneer 7100 GM 800 Watt max amp
Home > Message Board > Car Audio > Amplifiers > Archive through March 28, 2006 > Wiring Configuration [ « Previous ] [ Next » ]
