Thread: What kind of system should i buy |
New member Username: Warrior
Post Number: 1 Registered: Apr-04
| Posted on Friday, April 30, 2004 - 03:08 am: |
Hi, All i have $1900.00 and i am wanting to know what is the best system i could get with that. It will go in a 01 ford explorer. I would like it all to be the same brand name. Can someone help me? |
NorthWest,
Michigan
Post Number: 2540 Registered: Dec-03
| Posted on Friday, April 30, 2004 - 01:22 pm: |
well, generally you won't get everything the same brand. some companies are better at one line of things than others try.. Eclipse head unit JL Audio XR series front and rear components JL Audio amplifiers JL Audio W6v2 series subs knukonceptz.com power cable and interconnects that's mostly the same company and all great products
Bronze Member Username: Pat_l
Tucson,
AZ
Post Number: 36 Registered: Apr-04
| Posted on Friday, April 30, 2004 - 06:59 pm: |
I tell ya go with three subs. Its an SUV lots of room! |
NorthWest,
Michigan
Post Number: 2568 Registered: Dec-03
| Posted on Friday, April 30, 2004 - 07:46 pm: |
he has a budget. he'd be just as well off with two good subs, sufficient power, and good boxes
Post Number: 2 Registered: Apr-04
| Posted on Monday, May 03, 2004 - 04:46 pm: |
Hey glasswolf about how many dbs do you think i could get that system up too. |
Bronze Member Username: Steveo
CA
Post Number: 45 Registered: Mar-04
| Posted on Monday, May 03, 2004 - 04:51 pm: |
I suggest the CDTs for $149. The X-overs have an output for imaging tweaters which I bought also ($49.99). I had the JL XRs before my car was stolen 499.00. The CDTs are louder, but may lack a little in SQ; however, defenetly not $350 worth... In addition, the imaging tweaters are great. They bring the sound up to head level and bring great imaging for the $$$. Good luck, STeveO All purchased at the Zeb www.thezeb.com. Great company that sends items fast and free shipping. |
NorthWest,
Michigan
Post Number: 2664 Registered: Dec-03
| Posted on Monday, May 03, 2004 - 06:59 pm: |
CDT makes very good components. I was just sticking to his one company theme. for that matter to save a bit of money without losing much, look at Clarion for a head unit, Kicker KX600.4 as a 4 channel amp for mids/highs, a Kicker KX1200.1 for subs, CDT for components front, and if desired, rear, and JL, MMATS, or Image Dynamics (ID) for some good subs. won't be a themed system, but it'd be good SQ. you could look at audiocontrol for signal processing/EQ stuff if desired as well. as for SPL, no way to tell.
Post Number: 3 Registered: Apr-04
| Posted on Tuesday, May 04, 2004 - 01:05 pm: |
i think i found what i want can someone tell me what they think about this. Eclipse CD3413 head unit JL Audio 500/1 amplifier JL Audio 300/4 amplifier JL Audio 12W3v2-D4 subs JL Audio XR525-Csi component JL Audio XR650-Csi component |
| Posted on Tuesday, May 04, 2004 - 02:12 pm: |
go for the better eclipse head unit. maybe a 5444 |
NorthWest,
Michigan
Post Number: 2706 Registered: Dec-03
| Posted on Wednesday, May 05, 2004 - 10:42 am: |
good layout, and good advice there.
Post Number: 6 Registered: Apr-04
| Posted on Wednesday, May 05, 2004 - 01:36 pm: |
Thanks for all the help guys i have ordered the system and i will post again once i get it installed and tell everyone what i think about it. thanks again for the help. |
jlisking Unregistered guest |
| Posted on Wednesday, May 05, 2004 - 07:14 pm: |
I have 3 12 inch jl audio w0 i am just wondering what is a good cheap amp that will make these sound good with alot of bass. And should i go wiht a ported or sealed box |
| Posted on Wednesday, May 05, 2004 - 07:28 pm: |
start a new thread and someone can help you better. |
