Thread: Buzzing |
New member Username: Meat_pops1cle
Post Number: 8 Registered: Nov-05
| Posted on Wednesday, March 22, 2006 - 05:10 pm: |
ok, my amp to my mids blew 2 weeks ago, got the replacement (different type, same brand) today, hooked it up and i have buzzing in my speakers. also when i turn the volume to 0 it makes a popping sound thru the speakers....also the engine puts feedback on speakers now, I'm a tad confused and was thinking that maybe my ground needs to be better? but i dunno, please help!! |
Gold Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 1460 Registered: Feb-05
| Posted on Wednesday, March 22, 2006 - 05:26 pm: |
i'd say it sounds like a grounding issue or how you have the wires run. RCA's and power leads on opposite sides. check the grounds. possibly change the RCA's to some better ones... |
Post Number: 9 Registered: Nov-05
| Posted on Wednesday, March 22, 2006 - 05:32 pm: |
Hrm, i'll mess with the rca's they cross over the Power cable close to the amp, i'll see what happens. btw, is there a way to improve grounding on my car? |
