Home > Message Board > Car Audio > Amplifiers > Archive through March 28, 2006 > These good amps?
Author Thread: These good amps?
Username: Kingjames
OH
Post Number: 70
ever heard anything good about the 1600 Alphasonik amp or the AMple audio 1500 watt amp i trying to figure out what to buy just wanted to knoiw if these are good for the money or should i go another way? btw im getting a havoc so if u give suggestions make sure they are compatible
Username: Ctmike
Ct.
Post Number: 90
i've heard good things of this amp, when i can get a new car i'm actually thinking of a havoc and this amp.
http://edesignaudio.com/product.php?cid=4&pid=6&cur=USD,
or a maybe one of these:
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13472
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13884
http://ikesound.com/product-product_id/2425
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 247
i'll say go with viper
Username: Kingjames
OH
Post Number: 71
would the viper be better cuz its 2500 instead of 1500, or would that just be like wasted watts?
or should i go with a higher quality amp and have it only be 1500watts?
Username: Ctmike
Ct.
Post Number: 94
if you look the viper is rated at 1500@4ohms, so it would work perfectly since the havoc is also rated the same.
Username: Kingjames
OH
Post Number: 75
any other suggestions, or does this viper seem like the best plus it is only about $375 shipped
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 253
i told you man, better deal and matches with your subs
Home > Message Board > Car Audio > Amplifiers > Archive through March 28, 2006 > These good amps? [ « Previous ] [ Next » ]
