Thread: Lanzar amps? |
Bronze Member Username: _jay_
Post Number: 16 Registered: Mar-06
| Posted on Wednesday, March 22, 2006 - 03:03 pm: |
how good r these amps..i was thinkin not that great cuz u can get alot of watts for little $ but i was just wondering..... |
Silver Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 249 Registered: Dec-05
| Posted on Wednesday, March 22, 2006 - 05:28 pm: |
some are overrated, others are not, better go with opti line. If you need class D amps the you use opti line, heritage 2600d, vibe 1200d or vibe 1800d. Those are the most reliable for mono. |
Post Number: 17 Registered: Mar-06
| Posted on Wednesday, March 22, 2006 - 10:05 pm: |
um i need an amp that will power 2 swx-1242's... and lanzar looked lyke it would do it..but was kinda on the cheap side |
Silver Member Username: Themax96se
Post Number: 112 Registered: Jan-05
| Posted on Thursday, March 23, 2006 - 01:48 am: |
Alpine Type X subs are good subs. Dont use crappy power. Good subs need good amps. |
Gold Member Username: Chaunb3400
Huntsville,
Alabama
U.S.
Post Number: 6265 Registered: Jul-05
| Posted on Thursday, March 23, 2006 - 01:49 am: |
budget |
Post Number: 20 Registered: Mar-06
| Posted on Thursday, March 23, 2006 - 11:45 am: |
150-250$... |
Silver Member Username: N2audio
Lawrence,
Ks
Post Number: 741 Registered: Mar-04
| Posted on Thursday, March 23, 2006 - 11:55 am: |
"Good subs need good amps" They need power, frequency control and a good enclosure. The name on the amp has little to do with it. Expensive amps defintitely have their benefits, but "good subs need them" isn't one of them. That being said - To really make those subs sing they're going to need close to 1000w rms a piece. That means an amp that's close to 2000w at 1 ohm. That isn't doable on your budget. The Vibe 1800D would be around 600w per sub, the heritage 2600d is a bit more - probably what I would recommend since they're about the same price. Within your budget the only other option that comes to mind is the Hifonics bx1605 at onlinecarstereo.com which is appx. the same power as the 2600d.
Silver Member Username: Fiber
Post Number: 109 Registered: Mar-06
| Posted on Thursday, March 23, 2006 - 12:12 pm: |
I ordered the Hifonics 2500D for $288 off ebay 2000 watts rms (1800) |
