Thread: Legacy Audio American Legacy II LA690 |
New member Username: Bobha
Post Number: 10 Registered: Feb-06
| Posted on Wednesday, March 22, 2006 - 06:27 am: |
American legacy II LA690 amp: i want to know if there is any way you can bypass the overhaul (green light:power, red light:overhaul) because when ever i bridge the amp it shuts off and i don't want it to Thanks.
Silver Member Username: N2audio
Lawrence,
Ks
Post Number: 736 Registered: Mar-04
| Posted on Wednesday, March 22, 2006 - 11:22 am: |
it's shutting off for a reason. What speakers are you trying to run? Do you know what impedance they are wired for? Where is the gain set? When bridged that amp is only stable at 4 ohms mono and will/should shut down at impedances lower than that. |
Bronze Member Username: Rustysurfer916
Post Number: 51 Registered: Mar-06
| Posted on Wednesday, March 22, 2006 - 01:43 pm: |
buy another amp. that ones a cheap peace of $hit. |
Bronze Member Username: Ton
Post Number: 22 Registered: Jul-05
| Posted on Wednesday, March 22, 2006 - 02:46 pm: |
yep, do what matt said |
Post Number: 71 Registered: Mar-06
| Posted on Thursday, March 23, 2006 - 03:00 pm: |
legacy is about the cheapest brand out their along with pyle. trust me ive had that $hit. spend the extra money its deffenatily worth it dont be a cheapass |
Gold Member Username: Tjmutlow
Post Number: 1741 Registered: Sep-05
| Posted on Thursday, March 23, 2006 - 03:28 pm: |
unbridge that amp the ohm load is to much, no ore then 4ohm. |
