Thread: 3 Type R, and 8 speakers |
New member Username: Cbear503
Post Number: 1 Registered: Mar-06
| Posted on Wednesday, March 22, 2006 - 03:37 am: |
well just bought another type r cause i ran by it at a swap meet. my original set up is like this. 2 12inch Type Rs rigged up to a Kenwoord KACX-520 with PG Ti Cap, 2 Pioneer 4 way 6x9s and 6 Pioneer 4 way 6.5s rigged up to two PG Old school TI 500.4. What now? I had a sealed box but now i'm going custom fab with fiberglass. I have no back seat so plenty of room to work with. |
Silver Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 245 Registered: Dec-05
| Posted on Wednesday, March 22, 2006 - 12:46 pm: |
first buy a new alternator, then buy some batteries |
Gold Member Username: Bestmankind
Los Angeles,
CA
Post Number: 3258 Registered: Oct-05
| Posted on Wednesday, March 22, 2006 - 01:05 pm: |
after the alt and batteries change that amp. not a big fan of kenwood. what are the specs to that amp? too lazy to do a search. |
Post Number: 250 Registered: Dec-05
| Posted on Wednesday, March 22, 2006 - 05:30 pm: |
jajaja |
Bronze Member Username: Ctmike
Ct.
Post Number: 93 Registered: Feb-06
| Posted on Wednesday, March 22, 2006 - 05:34 pm: |
after getting new battery and ho alt., if you have the budget, i would get three of these, just to keep a custom alpine look: http://www.alpine-usa.com/en/products/product.php?model=MRD-M605 and try to get them mounted somewhere kinda below the subs in the enclosure, and maybe get a small neon light hidden in front of the amps too! |
Post Number: 2 Registered: Mar-06
| Posted on Friday, March 24, 2006 - 12:29 pm: |
Those m605s look pretty good, i'll have to shop around for a price, I have a red optima battery hooked up now, which one is good for the stand alone? |
