Thread: Jensen vm9510ts Parking Brake bypass.... |
New member Username: Mattyb777
Post Number: 2 Registered: Mar-06
| Posted on Tuesday, March 21, 2006 - 11:52 pm: |
Can anyone tell me EXACTLY how to bypass the ebrake? One wire is supposed to go to the gearbox switch, the other is supposed to go to the parking brake switch. Any info you can give would be great!! |
Gold Member Username: Tjmutlow
Post Number: 1728 Registered: Sep-05
| Posted on Wednesday, March 22, 2006 - 04:05 am: |
just ground the parking brake wire... |
Post Number: 3 Registered: Mar-06
| Posted on Wednesday, March 22, 2006 - 02:18 pm: |
Thanks for your help! Worked great...not very impressed with the sound quality though...might have to sell this one and upgrade already! Thanks again! |
Post Number: 1732 Registered: Sep-05
| Posted on Wednesday, March 22, 2006 - 04:46 pm: |
ask before you buy the next, try an panasonic, alpine or pioneer. |
New member Username: Jayce2000
Post Number: 3 Registered: Jun-06
| Posted on Friday, June 16, 2006 - 02:49 pm: |
Grounding the wire will cause damage on the VM9511TS radio.The correct way of doing it is the following: You cant just ground it this year you actually need a switch to do it...Ground one end of the toggle switch and then the other end of the switch to the pink wire.Put in the DVD,the blue screen will come up telling you you cant watch the movie while driving.Flip the switch UP,DOWN and then back up again and you should be fine..One catch though,when you go to get out of the car,flip the switch back in the DOWN position.. BTW....Pioneer and Alpine dont have near the features or the screen size and the Panasonic is a full year behind in technology...Maybe upgrade your speakers or add an amplifier..Jensen has 5 of the top 10 MM units out on the market so they must be doing something right!!! |
Post Number: 4 Registered: Jun-06
| Posted on Friday, June 16, 2006 - 02:51 pm: |
I had your message and another backwards with the wiring feature..The one you have is just grounding the pink its the 9511TS that needs the switch..Sorry for the reply... |
New member Username: Mrbelvedr
Fairfax,
VA
United States
Post Number: 1 Registered: Jun-06
| Posted on Thursday, June 29, 2006 - 01:41 am: |
I am not an electrical engineer, but there must be a more sophisticated way to do this! Anybody have an idea? I think a simple circuit that simulates chaning phases, (1) off (2) electrical 12 volt on (3) parking brake engaged. |
New member Username: Albatross83
Post Number: 2 Registered: Oct-06
| Posted on Friday, October 06, 2006 - 02:01 am: |
I'm thinking of buying the vm9511ts.. it's the only in-dash DVD player I found with an SD slot, TV tuner included, and iPod controls. Hopefully the grounding method will work for bypassing the parking brake. As for the sound quality, I haven't found a local retailer who sells the unit, so I haven't been able to listen to it firsthand. Is the audio quality really that bad? Wouldn't using the RCA outs into a decent amp mitigate any shortcomings of the internal amplifier? |
Silver Member Username: Makmillion
MN
United States
Post Number: 974 Registered: Apr-06
| Posted on Friday, October 06, 2006 - 02:22 am: |
Jensen is an Audiovox product, and they use Audiovox screens which happen to have AMAZING clarity but sluggish refresh rates. The Pioneers, Alpines and Panasoincs all use Panasonic screens which aren't as clear as the Jensen/Dual/Audiovox screens but the refresh rate is alot better If you choose to go with a Jensen/Dual/Audiovox unit, know that you will need to use an external EQ to get optimal sound, as well as making sure the external EQ has a nice line driver built in.. clarion makes a nice EQ with 7 volt preouts, 6 band graphic EQ with a 1 band parametric sub EQ built in... so 7 band total. Anyways, just a little advice. |
New member Username: Dchap
Pittsford,
New York
Post Number: 5 Registered: Sep-06
| Posted on Friday, October 06, 2006 - 06:32 am: |
There is a module on e-bay for sale that electrically does the switch flipping for you. I little expensive but I didn't feel like spending the time designing one. It works perfect. For those that are electrically inclined a small circuit could be built using a 555 timer IC. I could design it, but like I said, it was easier and faster to just buy one. |
