Thread: Foam Speaker Baffles |
Gold Member Username: Sploosh56
Ohio
Post Number: 1214 Registered: May-04
| Posted on Tuesday, March 21, 2006 - 10:19 pm: |
Anyone use these for their front speakers? Do they make a difference good or bad? |
Gold Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 1449 Registered: Feb-05
| Posted on Wednesday, March 22, 2006 - 12:22 am: |
i have them on mine, but have the back/bottoms cut out so i only have a cover over the top to keep water away. lol honestly, they will limit the air space and kill bass responce. i wouldn't use them for anything other then what i mentioned above. |
Ohio
Post Number: 1218 Registered: May-04
| Posted on Wednesday, March 22, 2006 - 06:57 am: |
ok thanks |
New member Username: Van_man
Post Number: 2 Registered: Mar-06
| Posted on Thursday, March 23, 2006 - 07:51 pm: |
I have hard plastic baffles and it def helps out the bass on 6x9s |
