Home > Message Board > Car Audio > Amplifiers > Archive through May 14, 2004 > Help i need an amp
Author Thread: Help i need an amp
Username: Steve
Louisville, Ky
I have two Alpine Type Es 12 inch subs. What kind of an amp should i use . I heard a 1,000 watt kenwood. Is that too much or just enough?
Username: Burkholderl
Michigan
US
You would respect my amp!
check it out
http://www.ampdepot.com/car/sgl-prod/amps/kole/hk19202.htm
that amp is a total piece of crap!!!
Username: Its_bacon12
Post Number: 499
true man... so are all the amps that place carries..
get a JBL bp600.1
Username: Vipersbyms
Post Number: 61
the type e's are 200 watts rms, 600 is a little too much. these amps are stable at 2 ohms and would be a good match...
mtx 421D
kicker kx400.1
Username: Soccer
Post Number: 60
It's always preferable to connect a stronger amp to a weaker speaker than the opposite, due to current issues...
Post Number: 63
type e's arent the greatest subs ever made, that amp is underrated so it will putting out closer to 700 watts, almost twice what the rms of the combined. those other amps also will be underrated so it should push them very well.
those amps aren't weak, and those subs arent strong.
Username: Tremsy
I am just starting out right now on buying car subs and amp. I want 1 15 and an amp that can power it. Whats a good sub thats 15 inchs and an amp that can power it. If you could give websites or prices too.
try a Kicker CVR15-4 sub and a Kicker KX350.2 amp. bridge it and that will sound great. take a look at them at this site.
http://www.acaraudio.com/
Username: Mtxman780
LOUISVILLE, KY
try the mtx 81000d
Home > Message Board > Car Audio > Amplifiers > Archive through May 14, 2004 > Help i need an amp [ « Previous ] [ Next » ]
