Home > Message Board > Car Audio > Amplifiers > Archive through March 28, 2006 > Which amp for 2 L7s
Author Thread: Which amp for 2 L7s
Username: Highstone
Post Number: 45
need an amp to push my 2 12" kicker L7s. i'm planning to use 1 (2channel amp). each sub is 750 watts RMS (1500 peak power)
Username: Southernrebel
Monroe, Louisiana
Post Number: 2491
what voice coils do they have? (DVC 2ohm or DVC 4ohm?)
you will be better off w/ a class-d amp. (1 channel)
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 243
if they're DVC 2 ohms, some will disagree but you can buy lanzar optidrive that is 1900w rms at 1/2 ohm, and if you have the dual 4 ohm version then you can buy a ED nine 1 or hifonics bx1605 if you're on a budget
Monroe, Louisiana
Post Number: 2499
even if they are DVC 2ohm subs...you can get class-d amps that put out 1500w+ at 2ohms.
(ex: MTX, kicker)
Username: Highstone
Post Number: 48
it's 4 ohms.. and i really want 1 amp.. don't have place to put another one..
Username: Rovin
Trinidad & T...
Post Number: 6804
PPI DCX1500
OR DIAMOND AUDIO
D61500.1 .....
Monroe, Louisiana
Post Number: 2500
^i agree w/ rovin.
Username: Highstone
Post Number: 49
guyzzz.. i wan 1 amp that has 2 channels. that can support 2 kicker 12" L7s.
Username: Rovin
Trinidad & T...
Post Number: 6806
thats gonna be expensive & draw more current
D class (MONO) amps r especially made to run subs .....
Username: Highstone
Post Number: 50
well then how would i connect the two amps for the subs.. would the RCAs go to one amp and they will be connected by some wire.. so something else..
Username: Highstone
Post Number: 51
or do u want me to connect both subs to 1 channel amp.. if so .. is that possible..
Username: Rovin
Trinidad & T...
Post Number: 6807
those amps i mentioned above
u onlt need 2 buy 1 of either .....
Username: Rovin
Trinidad & T...
Post Number: 6808
Only i meant ^....
Username: Highstone
Post Number: 52
so how would i connect 2 subs to 1 one-channel amplifier?
Username: Nemen
Post Number: 651
if they are single 4ohms wire them in parallel and youll have a 20hm load so you will need a amp stable at 20hms
Username: Highstone
Post Number: 53
if the subs are 4 ohms or amp is 4 ohm.. can u explain.. maybe a diagram.. sorry i'm very new at this..thanks
Home > Message Board > Car Audio > Amplifiers > Archive through March 28, 2006 > Which amp for 2 L7s [ « Previous ] [ Next » ]
