Thread: Pick a good amp off of my list. |
Bronze Member Username: Rmzracer
Bentonville,
Arkansas
Post Number: 94 Registered: Jul-05
| Posted on Tuesday, March 21, 2006 - 06:30 pm: |
I got two 4ohmDVC alpine type r's these are the amps im looking at. Phoenix Gold 15.0.1 Mb Quart RAA1000 Hifonics 1500d Im leaning towards the Mb quart or Phoenix but im not sure if the Phoenix has enough power i really can't find a good rms reading. HELP!! |
Gold Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 1441 Registered: Feb-05
| Posted on Tuesday, March 21, 2006 - 06:44 pm: |
all the ratings for the PG ams are Max, even from the web site. so that sucks, shouldn't ever go by max ratings. do know the Hifonics puts out about 70% of its rating from what i've read. never heard any complaints about the MB Quart. looks like a great amp. out of thoes, i'd pick the Quart. i don't know if its 1 ohm stable though. better make sure. |
Silver Member Username: Dustin3
Tigard,
Or
U.S.
Post Number: 609 Registered: Oct-05
the pheonix gold amp is 700 x 1 @ 4 ohm 1500x 1 @ 2 ohms since you have two 4 hom subs, you can wire those only to 1 ohm or 4 ohm. so if you were to go with that amp you would only be gettin 700 watts @ 2 ohms The MB Quart RAA1000 Reference Series 4 Channel 1000 Watt Mono Amplifier: this is a 4 channel amp for hooking 4 speakers or 2 speakers and a sub, so i would pick a mono-channel or 2-channel amp. The hifonics amp i think would be the best one there because it puts out 1500 (1348) watts @ 1 ohm. so you would wire your subs to one ohn and get around 620 watts to each sub |
Tigard,
Or
U.S.
Post Number: 610 Registered: Oct-05
| Posted on Tuesday, March 21, 2006 - 06:46 pm: |
it says the mb quart is a mono amplifier, but it is a 4-channel amplifier. hmm.. i would still go with the hifonics, i know for a fact is puts out 1348 watts because i know alot of people who benched it. most hifonics amps are 70-80% overrated, but the 1500d isnt that much. |
Bentonville,
Arkansas
Post Number: 95 Registered: Jul-05
| Posted on Tuesday, March 21, 2006 - 06:48 pm: |
actually the MB is a mono amp. |
Bentonville,
Arkansas
Post Number: 96 Registered: Jul-05
| Posted on Tuesday, March 21, 2006 - 06:50 pm: |
it is a mono block and has two speaker inputs. |
Tigard,
Or
U.S.
Post Number: 612 Registered: Oct-05
| Posted on Tuesday, March 21, 2006 - 06:52 pm: |
"The MB Quart RAA1000 Reference Series 4 Channel 1000 Watt Mono Amplifier puts power behind your car stereo system for outstanding sound quality from your speakers. With 4 channels, you can control the flow for optimal power levels to 4 speakers, or 2 speakers and a sub. These new units are perfectly matched to the MB Quart loudspeaker systems, and are equipped with a range of special features that make them the best in their class." |
Tigard,
Or
U.S.
Post Number: 613 Registered: Oct-05
| Posted on Tuesday, March 21, 2006 - 06:55 pm: |
you can get whatever you want but thats just what i found on their websight. i havent heard of a 4-channel mono amp before but as long as it puts around 1500 watts @ 4 or 1 ohm. you'll be fine |
Bentonville,
Arkansas
Post Number: 97 Registered: Jul-05
| Posted on Tuesday, March 21, 2006 - 06:59 pm: |
http://www.ikesound.com/product-product_id/4139 http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14965 these are the sites i am looking at. So lets say it has two inputs. If i wire both of my subs @ 2ohms and use each input that will present a 1ohm load correct? |
Tigard,
Or
U.S.
Post Number: 616 Registered: Oct-05
| Posted on Tuesday, March 21, 2006 - 07:12 pm: |
you cant wire 2 4 ohm subs to 2 ohm. 2 4 ohm subs to 1 and 4 ohms. and 2 2 ohm subs to .5, 2 and 8 ohms |
Bentonville,
Arkansas
Post Number: 98 Registered: Jul-05
| Posted on Tuesday, March 21, 2006 - 07:17 pm: |
i can wire them seperatly to get a 2ohm load apiece. ;) |
Gold Member Username: Rovin
Trinidad & T...
Post Number: 6786 Registered: Jul-05
| Posted on Tuesday, March 21, 2006 - 07:31 pm: |
{Hey - lemme enlighten u guys cause i have the very same subs & MB AMP ! http://forum.ecoustics.com/bbs/messages/4/189456.html do read what i said about using a bigger amp almost 2 the end of my thread . My advice DO NOT BUY that MB Amp ! - its really a gr8 amp 4 maybe a pair of 400wrms subs but the least amp i would rec is a kicker 1200 or orion 1200 D . I'd even go high as a PPI DCX1500 amp if u have the $ ........} |
Bentonville,
Arkansas
Post Number: 100 Registered: Jul-05
| Posted on Tuesday, March 21, 2006 - 07:42 pm: |
hey rovin to late pimpn i bought it. I didnt have much more than 200 to spend and it was looking primo since ikesound doesnt have the 1200d. But how did you have yours hooked up? Did you have them bridged or wired seperatly? |
Trinidad & T...
Post Number: 6789 Registered: Jul-05
| Posted on Tuesday, March 21, 2006 - 07:52 pm: |
with a 200 budget u could prolly get a Hifonics bx1500d on ebay - cant u cancel ur order ? gr8 MB amp like i said but Rs can handle more as u can see in my install i built 2 separate boxes & tuned to around 35hz so yes 2 separate wires u need 2 wire each sub lie thia onto each + & - terminal on ur amp which would result into a 1ohm load ...... |
Silver Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 241 Registered: Dec-05
| Posted on Tuesday, March 21, 2006 - 07:57 pm: |
MB quart, good deal, hifonics 1500d, better deal |
Silver Member Username: Rmzracer
Bentonville,
Arkansas
Post Number: 101 Registered: Jul-05
| Posted on Tuesday, March 21, 2006 - 09:50 pm: |
well the mb was 226 shipped. And ive tried to get two hifoincs 1500d's and both of them were out of stock. The ones i found on ebay were about 270 shipped so that was outa the question. I wanted thr orion 1200d but ikesound is out so the mb will do. |
Tigard,
Or
U.S.
Post Number: 622 Registered: Oct-05
| Posted on Tuesday, March 21, 2006 - 10:49 pm: |
there is other places you could have gotten it. there are tons of site's out their. the 1500d, like i said at the beginnin of this thread, would be the best choice. you know how to wire that joey? just asking because alot of poeple mess up on the wiring so make sure you got everything understood and down. like, you run two speaker wires from one vc to the other vc. it doesnt have to connect the amp. it just completes the circuit. this is the questions that get asked alot on this site... |
Bentonville,
Arkansas
Post Number: 102 Registered: Jul-05
| Posted on Tuesday, March 21, 2006 - 11:20 pm: |
dude this aint my first rodeo. but thanks for checking. yeh i know what to do. i was going to wire them parallel parallel and bridge them but i guess i'll just wire each in parallel so i use both inputs. But on the 1500d i tried ebay twice both times had to get my money back cuz it was out of stock. Then i tried onlinecarstereo.com both the 1500d and the 1600d were out of stock. so i gave up |
Tigard,
Or
U.S.
Post Number: 629 Registered: Oct-05
| Posted on Wednesday, March 22, 2006 - 07:24 pm: |
yea, i would keep cheking though. |
