Home > Message Board > Car Audio > Amplifiers > Archive through March 28, 2006 > How do I need to wire this??
Author Thread: How do I need to wire this??
Username: Error_505
Amory, MS
Post Number: 33
How would I wire this to be at 250 watts @ 2 ohms? Or would bridged 500 watts x 1 @ 4 ohms be better? I know how to bridge it, but would like to go 2 ohm if it is better. Any suggestions would be helpful. BTW I did buy this amp and I do have these speakers, so this is not theoretical.
Thanks for your answers!!
Rockford Fosgate Punch P5002
2 channels
125 W x 2 @ 4 Ohms RMS
250 W x 2 @ 2 Ohms RMS
500 W x 1 @ 4 Ohms Bridged RMS
HP 40-400Hz 12dB per Octave
LP 40-400Hz 12dB per Octave
Frequency Response 20 to 20k Hz +/- .5 dB
Remote Punch Bass
RCA Inputs
RCA Pass-thrus
Class A/B topology
2.4 X 11 X 13.7 (inches)
Rockford Fosgate 12" Punch Stage 2 Subwoofer
400 Watts Maximum Power Handling / 200 Watts RMS
4 Ohm Single Voice Coil Operation with Parabolic Polypropylene Cone
Username: Dustin3
Tigard, Or
U.S.
Post Number: 603
it doesnt matter what you do. 2 ohm and 4 ohm doesnt matter. it only matter in what your amp can handle. for wiring help use this website, it will tell u exactly:
www.the12volt.com and then go to woofer wiring
Username: Error_505
Amory, MS
Post Number: 36
Speakers wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono
My amp isn't mono so how would I wire it? Bridge it and wire it like this?
Username: Tjmutlow
Post Number: 1697
no, your amp is stable at 4ohms bridged, you can not run it bridged with 2 single 4ohm subs...
Username: Error_505
Amory, MS
Post Number: 39
Should I try to get 8 ohm p2's? You guys are telling me what I can't do do, but not what I can do. Please give me something positive.....lol But thanks for the input
Username: Tjmutlow
Post Number: 1705
yes, use 2 single eight ohm or 2 dual 4 ohm subs.
Username: Error_505
Amory, MS
Post Number: 42
Those 8 ohm speakers are hard to find for a good price. I haven't checked on DVC though. Thanks!
Username: Koz1031
Monticello, In
United states
Post Number: 427
run the speakers in parallel and bridge the amp you'll be fine then
Username: Tjmutlow
Post Number: 1731
no you wont, amp not stable at 2ohms bridged....
Username: Dustin3
Tigard, Or
U.S.
Post Number: 628
the first thing you should have looked at is dvc 4 ohm subs...
Username: Error_505
Amory, MS
Post Number: 49
Yes I know that now...lol I am buying a new amp. It is the T5002. I thought they said P5002 over the phone, very easy to be confused. The T5002 should work fine from the 4 ohm svc subs I have. I sure hope so.....lol Thank you all for the posts and the help. You are a great group of pple and Im glad I found you guys. BTW, I'm selling my P5002 for 190$ shipped. It is also listed on eBay.
Fosgate T5002 Power Amp
2 channel 75 W x 2 @ 4 Ohms RMS
150 W x 2 @ 2 Ohms RMS
250 W x 2 @ 1 Ohms RMS
300 W x 1 @ 4 Ohms Bridged RMS
500 W x 1 @ 2 Ohms Bridged RMS
500 Watts total power
2 Rockford Fosgate P212S4 12" Subwoofers SVC
- 4 Ohm Single Voice Coil Operation with Parabolic Polypropylene Cone
Username: Tjmutlow
Post Number: 1738
will be fine
Home > Message Board > Car Audio > Amplifiers > Archive through March 28, 2006 > How do I need to wire this?? [ « Previous ] [ Next » ]
