Thread: Alpine components installed incorrectly? |
Bronze Member Username: Gibson5469
Post Number: 35 Registered: Jul-05
| Posted on Sunday, March 19, 2006 - 06:15 pm: |
My friend had the Alpine SPR-17LS components installed in his Jeep, they didnt use the crossovers and told him that you only needed them if you used an amp. He also had an alpine deck installed. He wanted me to check out the system because on of the tweeters was crackling like it was blown, then I look in the back and there are the crossovers sitting in the box. These should have been utilized right? TIY |
Gold Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 1436 Registered: Feb-05
| Posted on Sunday, March 19, 2006 - 07:34 pm: |
you have to use the crossovers supplied with the components. they split the signals between the woofers and tweeters. tweeters should never receive low signals or they will crackle and blow. woofers shouldn't receive the higher frequencies either. the crossovers should absoultely be used!! |
Post Number: 36 Registered: Jul-05
| Posted on Sunday, March 19, 2006 - 08:06 pm: |
alright thats what I thought, thanks. |
Silver Member Username: Lbeckner
Tulsa,
Ok
Usa
Post Number: 776 Registered: Oct-04
| Posted on Sunday, March 19, 2006 - 10:04 pm: |
geeze who installed them? |
Post Number: 37 Registered: Jul-05
| Posted on Monday, March 20, 2006 - 01:26 am: |
installer from a local custom audio/video shop, not best buy or circuit city, did it after hours.I knew he screwed up, I think best buy or cc would have done a better job haha |
Tulsa,
Ok
Usa
Post Number: 778 Registered: Oct-04
| Posted on Monday, March 20, 2006 - 06:46 am: |
yeah, for sure. i hope you didn't blow your tweeter. if you did make the dumb@ss installer replace it. this is why i don't use local car shops. kick him in the face for me. |
Gold Member Username: Rovin
Trinidad & T...
Post Number: 6751 Registered: Jul-05
| Posted on Monday, March 20, 2006 - 10:40 am: |
go cuss that installer ....... |
