Thread: My Amp is broken - help please |
New member Username: Paddyaubs
Post Number: 1 Registered: Apr-04
| Posted on Wednesday, April 28, 2004 - 08:36 am: |
I have got a Kenwood amp and its decided to stop working I have used a DMM and there is 12V across power and earth terminals and 12V across earth and remote. Problem is - there is no light on and nothing going to my sub Any suggestions? |
Bronze Member Username: Soccer
Post Number: 50 Registered: Apr-04
| Posted on Wednesday, April 28, 2004 - 08:53 am: |
Have you checked the amp's fuse? |
Post Number: 2 Registered: Apr-04
| Posted on Wednesday, April 28, 2004 - 09:05 am: |
First thing i checked - checked both the one on the Amp and at the fuse box My knowledge of electronics isnt too hot |
NorthWest,
Michigan
Post Number: 2460 Registered: Dec-03
| Posted on Wednesday, April 28, 2004 - 09:21 am: |
either take the amp in for repair or buy a new one. I'd avoid kenwood next time.
Post Number: 56 Registered: Apr-04
| Posted on Wednesday, April 28, 2004 - 09:06 pm: |
Is there input? Something in between 200 mV AC and 1,5 V AC on RCA plugs on normal listening levels... Sometimes the worst malfuntions are the simplest... |
Bronze Member Username: Pat_l
Tucson,
AZ
Post Number: 27 Registered: Apr-04
| Posted on Thursday, April 29, 2004 - 12:09 am: |
It may not be the AMP i would say to check all contacts of the ground, power and remote. It could be bad connections- not the AMP! |
Post Number: 3 Registered: Apr-04
| Posted on Thursday, April 29, 2004 - 09:32 am: |
Grounding, power and remote is good and the signal coming in is fine. I know there wont be any sound coming out because the light isnt going on Its doing my nut in! |
New member Username: Armando
Post Number: 1 Registered: May-04
| Posted on Monday, May 10, 2004 - 10:03 pm: |
how do you connect a pc's power supply to an 200 watt amp |
| Posted on Tuesday, May 11, 2004 - 12:58 am: |
You said Fuse box, you don't mean your car's fuse box, do you? I hope you ran a separate wire. Anyway, Sounds like a bad amp, but I'd double check the remote wire just in case. |
Tucson,
AZ
Post Number: 85 Registered: Apr-04
| Posted on Tuesday, May 11, 2004 - 01:55 am: |
Yeah if the light doesnt turn on and you have giggled every possible wire than the amp is bad. Take it in to get it fixed. |
Post Number: 4 Registered: Apr-04
| Posted on Tuesday, May 11, 2004 - 03:40 am: |
A big thankyou to my namesake! Now all i need to do is find a decent ICE specialist in my area (easier said than done) If i was to replace it - is a JBL GTO 6000 a good amp to get? Have one on offer over here for £100 Thanks to all that posted |
Post Number: 5 Registered: Apr-04
| Posted on Tuesday, May 11, 2004 - 04:12 am: |
Oh and for the sake of the anonymous posting - i do have a separate wire running, but i have hidden the in-line fuse holder in the fuse box rather than haveing it dangle around in the engine bay |
